do i need a capacitor?
Old Dec 2, 2005 | 05:35 PM
VTmaximaVT's Avatar
I just got
10" Rockford power stage 1 sub (T110D4) 600W rms/1200w peak
JBL GTO 601.1 mono amp. 580W @ 2 ohm.
what do you guys think? do i need a capacitor? i'm a noob, your inputs are welcome.
thanks,
Old Dec 2, 2005 | 06:16 PM
AscendantMax's Avatar
nope, no need. they're more of a strain on your system. just make sure you use the correct size wires and have a good clean ground.
Old Dec 2, 2005 | 06:51 PM
DcMaN's Avatar
I Suggest a battery upgrade, a red or yellow top, as well as an upgraded ground to the battery that is your best bet.
Old Dec 3, 2005 | 10:35 AM
filtor1's Avatar
Another NO vote here as well. Proper wire size and a nice Yello Top under the hood should be plenty.
Old Dec 3, 2005 | 11:07 AM
VTmaximaVT's Avatar
thanks for your inputs!!
I got Q-Logic sealed/ported enclosure, and getting 4 gauge wires...
can't wait to get everything set up in the trunk...
If my stock battery don't do the work, i'll do battery upgrade...
thanks again, guys!
Old Dec 3, 2005 | 11:59 AM
filtor1's Avatar
Anytime. Your payment will be pics!
Old Dec 4, 2005 | 07:30 PM
NisAznMonk's Avatar
I'd say no. Depending on how much you get your yellow top for, a comparable www.kinetikaudio.com battery would work well also.
Old Dec 4, 2005 | 09:31 PM
VTmaximaVT's Avatar
thanks for good info, NisAznMonk.
btw, you guys are talking about replacing the stock battery, not getting extra battery in the trunk, right?? just making sure...
Old Dec 4, 2005 | 10:53 PM
DcMaN's Avatar
yea just replace the one up front, and add a 0 Gauge ground. When you replace the battery follow the negative cable and look to see how its grounded. You will want to replace it immediatly after seeing it . Usually its all corroded and green.
Old Dec 6, 2005 | 01:58 PM
talisman311's Avatar
I vote yes. I recommend 1f/500watts rms. Not only gives your system more juice but also functions as a voltage stiffener. I'd also upgrade the big 3 (esp. ground). Don't waste your money on a yellow top unless you wanna drain your system ALL the way down and slow charge the battery back up. Spend it on an upgrading the alternator.
Old Dec 6, 2005 | 11:08 PM
cmosanna's Avatar
The only way you really know you need a capacitor is after your system is installed and u have it cranked at night and your headlights dim when the strong bass hits, then you probably should get one.
Old Dec 7, 2005 | 12:02 AM
slickrick's Avatar
my headlights do not dim but i still need the big 3 done and/or a new alti...NOT a new Cap. a big NO vote on the cap. send me the $ and ill put it to better use than you can do with a cap.
Old Dec 7, 2005 | 12:18 AM
SEmy2K2go's Avatar
Go BUCKS!!!
This cap is doing about as good of a job for this guy as one would do in your car.
Old Dec 7, 2005 | 12:43 PM
nope, he can just upgrade his grounds and it should fix the dimming. caps are a waste of money imo.
Old Dec 7, 2005 | 01:32 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
Heres Your Answer
there you go...and you dont need it.
Old Dec 10, 2005 | 03:09 AM
VTmaximaVT's Avatar
i have factory HID headlights
do HIDs dim too???
Old Dec 10, 2005 | 07:53 AM
nope, HID just maintains an arc, not a glowing filament to produce light. plus HID consumes less power than halogens.
Old Dec 10, 2005 | 11:27 AM
slickrick's Avatar
do HIDs dim too???
nope. but i have seen my parking lights dim before.
Old Dec 14, 2005 | 09:58 AM
VTmaximaVT's Avatar
alright, I just got my amp/sub installed.
and all the lights are dimming with bass. and...yes HIDs are dimming too, but very lightly.
I'm thinking about getting capacitor or battery upgrade...
Old Dec 14, 2005 | 10:49 AM
slickrick's Avatar
do the BIG 3 also in addition to a new battery. how big is the stock alti? one 600 watt class d amp should not dim HIDS.
Old Dec 21, 2005 | 07:21 PM
quique's Avatar
a capacitor that you can easily find is a waste of money in ANY system, for a capacitor to really make a difference it would have to be closer to 50 farads than the 1/2 or one farad ones they sell. it will not help make it any cleaner or anything, here is why the capacitor only holds a charge momentarily, but when the voltage starts to drop it immediately discharges to oppose the change in voltage and bass notes in a song are longer than a capacitor takes to discharge so it helps for an instant then youre back where you started.
mb1
Aug 26, 2002 01:15 PM
mb1
Aug 26, 2002 12:38 PM
DaveGrun
Jul 23, 2002 06:34 AM
D1NOnly34
Jun 21, 2002 02:38 AM
Nick97SE
Jun 3, 2002 09:07 PM
