my subwoofer enclosure is too big!!
Old Dec 7, 2005 | 07:31 PM
VTmaximaVT's Avatar
Hi,
I just got Q-Logic type 2 sealed box. its interior volume is 1 cu.ft.
I have Rockford T110D4 sub and RF recommends 0.75 cu.ft. for sealed box.
now....can I just ignore 0.25 cu.ft. difference? If not, what's the best way to cut down 0.25 cu.ft?
thanks!
Old Dec 7, 2005 | 07:49 PM
AscendantMax's Avatar
i wouldn't worry too much about it. you'll just get a deeper bass extension from the larger box (and little less power handling)
if you really want, i'd try to put some kind of baffle inside the box to reduce interior volume. or...you can return the box and get a smaller one
Old Dec 7, 2005 | 08:48 PM
filtor1's Avatar
Originally Posted by VTmaximaVT
Hi,
I just got Q-Logic type 2 sealed box. its interior volume is 1 sq.ft.
I have Rockford T110D4 sub and RF recommends 0.75 sq.ft. for sealed box.
now....can I just ignore 0.25 sq.ft. difference? If not, what's the best way to cut down 0.25 sq.ft?
thanks!
Not to nit pick but I think you mean cubic feet, not square feet.
And there is nothing to worry about if it is a bit too big.
Old Dec 7, 2005 | 10:00 PM
slickrick's Avatar
no you will most likely like the sound better anyway.
Old Dec 8, 2005 | 10:12 AM
nismo0604's Avatar
always better than being to small my man
Old Dec 8, 2005 | 11:52 AM
VTmaximaVT's Avatar
oops, Thanks filtor1.
Old Dec 8, 2005 | 01:55 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
if you want to be on point
then you take away the woofe r displacement and add a length of 2x4 for bracing and keep adding until you meet your req'd airspace.
For that small of a difference I doubt youll have a problem and I wouldnt worry about it too much .
Old Dec 8, 2005 | 02:03 PM
VTmaximaVT's Avatar
Thanks guys for your advises.
according to most of you, I don't think I have to worry about it.
I measured the box, and it was about 1.1 cu.ft without the sub.
with the sub, the interior volume should be around 0.9 cu.ft.
Old Dec 8, 2005 | 02:19 PM
Chocolate_Boi_1Der
that is going to be neglegible, go with what you know.
Old Dec 8, 2005 | 02:53 PM
cool, didn't know that 10" displaces that much. my 15 RLp displaces .2 as well.
Old Dec 10, 2005 | 06:30 PM
Anethema's Avatar
Sub box too big
add fiberglass batting to reduce the interior volume.
Old Dec 11, 2005 | 03:03 PM
VTmaximaVT's Avatar
it was just my guesstimate.
Old Dec 11, 2005 | 09:04 PM
aaron-san's Avatar
i wouldnt worry about that small of a difference. Personally i like my bass a little deeper, which should be what you get with a bigger box.
D Mason
Jun 21, 2016 04:43 AM
MichMaxFan
Sep 30, 2015 09:18 AM
sliptap
Sep 30, 2015 05:57 AM
