"Err" on my bose?
Old Dec 19, 2005 | 01:20 PM
NewEngSurf's Avatar
"Err" on my bose?
Hey, havin a little bose problemes with my max (98 SE). I tried to play a cd-r on the bose which normally it can play but i got an error and then i put in a normall cd and got an error ("err") again. Is my bose ****ed or is this thing common?
Old Dec 19, 2005 | 11:16 PM
MxdOut97's Avatar
try a different brand of cd-r's, preferably something more high quality. that usually is the problem
Old Dec 20, 2005 | 02:11 PM
NewEngSurf's Avatar
No cd's are playing, reguardless of whether they are cd-r's or regular cds. Anyone experience this?
Old Jan 1, 2006 | 11:11 PM
White Shadow's Avatar
Still chugging along...
Yes it is common. Yes you are screwed. You can replace it or have it repaired. Neither is cheap. Repair by a competent knowledgeable technician for that problem may cost you close to $200. It may cost near the same to have it replaced with a used unit in good condition. Consider replacing the H/U and the speakers. It may cost more but you will probably be happier with the results if you buy quality equipment. .02
Old Jan 2, 2006 | 09:41 AM
NewEngSurf's Avatar
Yea, i already went ahead and bout my PAC and installed a new apline headunit. Thanks to nismo who helped me out. Is there anything i can do with my bose headunit, i thought i read somewhere that someone on the org sold theres to a company for like 50 bucks to be repaired and sold again?
Old Jan 2, 2006 | 11:26 AM
Tatanko's Avatar
Bacon Lover
Haha...Bose...hahahaha
My PAC is here as well...waiting on the headunit and the harness to go with it tomorrow. How'd yours turn out then BlackMax1992SE? Did you get all the problems sorted out?
Old Jan 2, 2006 | 11:32 AM
NewEngSurf's Avatar
Yea the bose sound good with the new HU. The only downside is that high piched S's in some songs sound distorted (hard to explain). Dont get confused when insalling ur PAC because only the speaker wires will go threw the PAC, the other wires (power, constant, antenna ect) do not go threw the pac they go around the PAC and straight to the headunit.
Old Jan 2, 2006 | 11:35 AM
Tatanko's Avatar
Bacon Lover
What do you mean "around"? Physically around? Or just that they go through the box but aren't altered at all?
Old Jan 2, 2006 | 12:54 PM
NewEngSurf's Avatar
physicaly around, there are 8 wires that go threw the box. Each speaker (4) has a + and - wire (4x2=8)
wiring harness --> PAC ---> Headunit
..................\___________/
............... (other wires path)
Old Jan 2, 2006 | 01:03 PM
Tatanko's Avatar
Bacon Lover
Ummm...why do they have to go around? Just curious.
Old Jan 2, 2006 | 01:17 PM
NewEngSurf's Avatar
The PAC is a "kick down" which means it bassicly tunes down ur headunit to not send its 45x4 watts to ur bose amps. Because if u sent all those watts to be amped, u will get way to much power and blow ur speakers. Your original bose headunit only signaled the bose amps to turn on, it didnt send any power to them. You still need or 12v's to go to ur Headunit (red and yellow wire) cant send them threw the kick down.
Old Jan 2, 2006 | 01:21 PM
NewEngSurf's Avatar
the diagram should actually look like this
Wireing harness <--- PAC <----- Headunit
.....................\______________/
The arrows representing the direction of the current. The headunit sends its sound threw the PAC inorder to "kick down" the power so it doesnt blow ur speakers after it goes threw ur amps.
Tatanko's Avatar
Bacon Lover
So basically connect the Bose wiring to the PAC...but on the other end where the loose wires are, only connect those 8 wires to the loose wires? Do I just tape off the other ones?
Great...now where do I get a power source and everything else? Mutilate the stock Bose wiring?
Old Jan 2, 2006 | 01:25 PM
NewEngSurf's Avatar
Your wireing harness has about 12 wires, 8 of which will go threw ur PAC in order to get to ur head unit. The remaining 4 or so will go around ur PAC and connect to ur Headunit. Those 4 or so wires are your Power, ground, antenna, constant.
Old Jan 2, 2006 | 01:33 PM
Tatanko's Avatar
Bacon Lover
12? I don't think so. There's 14 going into the PAC from the Bose wiring. Then I have 18 going to the headunit. So what needs connected, and what needs left alone?
Also, what does constant do? And I don't think I'll hook up the antenna because I don't want mine up all the time, nor do I have the proper adapter.
One last one: How do I adjust the 4 outputs?
Old Jan 2, 2006 | 01:38 PM
NewEngSurf's Avatar
Thats alot of wires. Mine only had the speaker wires that go threw the PAC
The constant is tiny constant flow of power that is always going to ur headunit so that it can remember such thing as time on the clock, and what ur programed ur presets to be, anything that needs to be "remembered"
Old Jan 2, 2006 | 01:45 PM
Tatanko's Avatar
Bacon Lover
Ohh. Interesting...
Which kit did you have? Mine is the PAC ROEM-NIS2.
Curious, which one is the constant...the orange wire? or the yellow? (orange = "illumination", yellow = "battery")
Old Jan 2, 2006 | 08:56 PM
nismos14's Avatar
§è~® f®ÈÄk
Pat just take urself out of this convo lol.
Old Jan 3, 2006 | 11:13 AM
Tatanko's Avatar
Bacon Lover
I have
After our conversation last night, I think I got it all down. My dad tells me all the stuff came in the mail today, too. So perhaps tonight
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
