What to do about dimming lights???
Old Dec 21, 2005 | 01:02 PM
hollaatchaboi's Avatar
I have 2 12" pioneers subs and a 600 watt Kenwood amp. Everytime the bass hits, all the lights dim. I have a voltmeter in the car and it jumps from 14- 12. What is the best fix for this? Should I put in a second battey, or get a cap? Any links to help me with this would be helpful. Thanx
Old Dec 21, 2005 | 01:12 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Combinattion of the two.
Batcap FTW
Old Dec 21, 2005 | 01:34 PM
if i put a 2nd battery, how do i wire it?
Old Dec 21, 2005 | 02:29 PM
Don't. It's pointless. GET THE BATCAP.
http://www.batcap.net/
DON HAS THESE...
Old Dec 21, 2005 | 11:01 PM
raga55's Avatar
hey, I don't know much about 2nd batts or caps, but the big 3 took care of my dimming problems, you might want to give that a try too
Old Dec 21, 2005 | 11:09 PM
Pearl96Max's Avatar
I tend to get a bit irritable
DON HAS THESE...
so get together a GD Dan, and Ill order them again.
Old Dec 22, 2005 | 05:35 AM
Hrmmm...I'll send you a PM later on today.
Old Dec 22, 2005 | 06:51 AM
I'll consider the bat cap....what is the big 3?
Old Dec 22, 2005 | 07:05 AM
brianjh's Avatar
Check all your grounds for the amp, a good ground should eliminate the problem !
Old Dec 22, 2005 | 07:15 AM
djfrestyl's Avatar
Suspension Yoda
What gauge wire are you running for that amp? Upgrade it. Upgrade your big 3 and you'll be on your way.
Old Dec 22, 2005 | 10:19 AM
filtor1's Avatar
I tried to eliminate the dimming in mine recently. I upgraded the big-3 with 0ga. I upgraded the power and grounds to 0ga. These seem to have had the most effect. I have had a second yellow-top in the trunk since the system was installed in Feb. The lights still dim at night at full tilt, but I suspected I would not be able to eliminate it totally. Sand down all your grounds properly and do the big-3 and see what that does. I have no experience with the batcap.
Old Dec 22, 2005 | 11:33 AM
OK....what is the big 3. Anyone have a link?
Old Dec 22, 2005 | 04:39 PM
filtor1's Avatar
Positive alternator to positive battery terminal.
Negative battery terminal to chassis
Chassis to engine(ground)
Old Dec 22, 2005 | 10:28 PM
Poowill's Avatar
DON HAS THESE...
Very interesting. But i'm a little confused. I have around 1300 total watts, what would i get? The Batcap 300? Does that replace my battery or just an addon? Sorry their site really didn't help me. If this will take car of dimming and alternator whine problems, someone should definately get a group deal going!
Old Dec 22, 2005 | 10:31 PM
Pearl96Max's Avatar
The 400 is the most common and its an add-on, not a replacement for anything.
Old Dec 22, 2005 | 10:36 PM
djfrestyl's Avatar
Suspension Yoda
Also, you said you had a 600 watt kenwood (I'll bet you're not seeing 600 watts with that). but anyway, where did the other 700 watts come from?
Many people run more without a batcap. Like we all said upgrade your wires then talk about batcap.
Old Dec 22, 2005 | 10:40 PM
Poowill's Avatar
I'm not the guy with the kenwood who started the thread.
Old Dec 22, 2005 | 10:41 PM
Pearl96Max's Avatar
Very true, although it would be great to get people in on a GD.
Old Dec 22, 2005 | 10:42 PM
djfrestyl's Avatar
Suspension Yoda
Apologies.
You should still upgrade wire before getting a batcap.
Old Dec 22, 2005 | 10:45 PM
Pearl96Max's Avatar
Apologies.
YOU stay in the garage...sales are Not for you.
Old Dec 22, 2005 | 10:53 PM
Poowill's Avatar
lol don, don't worry, i'll still consider it
by upgrading the wiring you mean do the big 3? Also is this the same as a grounding kit? like Blehmco sells?
Old Dec 22, 2005 | 10:54 PM
Pearl96Max's Avatar
Its all good, I was just bustin his *****. Ive never been pushy on sales. Hence the reason I carry alot of things that sell themselves.
Old Dec 23, 2005 | 11:40 AM
Anything with pics? Also what size wire should i use?
Old Dec 23, 2005 | 02:40 PM
TurTLe*'s Avatar
^ um its pretty str8 forward to a point where you shouldn't really need a picture at all.
Old Dec 23, 2005 | 02:50 PM
Quoted for tr00f
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
