HU Replacement and Bose Woes
Old Dec 25, 2005 | 02:01 PM
  #81
Tatanko's Avatar
Bacon Lover
Originally Posted by nismos14
I thought you had one, your' website says you have a mevi. Anyways. By front out puts I didn't mean on the face of the unit.
No no no, that's supposed to be how-to's for certain mods, not MY mods.
And sorry, I misread what you said earlier. I get it now
  #82
nismos14's Avatar
§è~® f®ÈÄk
Ya on the speaker wire part of the harness.
Old Dec 25, 2005 | 02:02 PM
  #83
nismos14's Avatar
§è~® f®ÈÄk
Lol good stuff mang.
Old Dec 25, 2005 | 02:03 PM
  #84
nismos14's Avatar
§è~® f®ÈÄk
Originally Posted by BlackMax1992SE
aight, when u say the harness. What harness? the one i have to buy for my car?
  #85
NewEngSurf's Avatar
This will give a signal to the bose, but not amplifying it. therefor it wont blow the speakers?
Old Dec 25, 2005 | 02:04 PM
  #86
nismos14's Avatar
§è~® f®ÈÄk
Exactly. It's like using low level inputs. Rca inputs to an amp just to the bose amps.
Old Dec 25, 2005 | 02:06 PM
  #87
NewEngSurf's Avatar
ok, but each speaker has a + and - wire, so that would be 8 wires. How do u splice 8 wires to an RCA?
Old Dec 25, 2005 | 02:08 PM
  #88
nismos14's Avatar
§è~® f®ÈÄk
Two wires to each FL FR RL RR, I think. I'm not 100% sure on that part.
Old Dec 25, 2005 | 02:10 PM
  #89
nismos14's Avatar
§è~® f®ÈÄk
Damn thats not right. I think you have to wire it to the stock bose harness not the aftermarket harness. One input to each wire.
Old Dec 25, 2005 | 02:32 PM
  #90
NewEngSurf's Avatar
Im gona stick with the pac. I dont mind paying extra money for convience
Old Dec 25, 2005 | 02:41 PM
  #91
nismos14's Avatar
§è~® f®ÈÄk
lol alright but if you got a better explanation u'd be ok i bet
Old Dec 25, 2005 | 02:56 PM
  #92
Tatanko's Avatar
Bacon Lover
We're on the same page
Old Dec 25, 2005 | 03:01 PM
  #93
NewEngSurf's Avatar
Yea, i like to keep it simple
So nismo, do u think my bose will eventually blow hooked up to my alpine, or should it be fine?
And if i did come down to replacing the speakers, would that be a ***** for audio noobs such as me and tatanko, i mean would i be ditching the PAC alltogether if i have to get rid of the bose speakers
  #94
nismos14's Avatar
§è~® f®ÈÄk
lol oh boy...If you saw how easy this was though, I bet you'd change your mind Save some bux too.
Old Dec 25, 2005 | 03:02 PM
  #95
nismos14's Avatar
§è~® f®ÈÄk
No they shouldnt blow unless you play them past the point of distortion. If you replace the speakers you just have to run new wires to the doors and to the rear speakers out of the headunit. Not hard to do at all. Especially on a 4th gen.
Old Dec 25, 2005 | 03:06 PM
  #96
NewEngSurf's Avatar
Good news
Maybe the recent downfall of my bose headunit is a good thing afterall. I mean i have a $300+ alpine headunit sitting in my basement but i didnt want to get into installing it because of the hassle of dealing with the bose. I mean if it aint broke, dont fix it. But now it is broke! So im probly gona keep it simple and put a bid on a PAC on ebay and install my alpine. Ill be sure to post pics when shes in, shes very nice.
  #97
Black Maxima
I put a Pioneer HU in my boy's Maxima. He has BOSE. I used the harness that came with the HU and one BestBuy gave us. I soldered the wires for each harness together. Color codeing is very easy. Make sure you wire the blue amp wires together. The only thing I noticed is that the volume is very sensative hooked up this way. Not too bad because the headunit has a volume level control setting.
Old Dec 25, 2005 | 03:11 PM
  #98
NewEngSurf's Avatar
So if i got my **** straight that harness that bestbuy gave u must have been similar to the PAC, or something that doesnt amplify the bose amps. Or else
Old Dec 25, 2005 | 03:24 PM
  #99
djfrestyl's Avatar
Suspension Yoda
RCA's are line level (low level) signals coming out of the HU
Every RCA plug has a + (the pin in the middle) and a - (the "shield" or ground ring on the outside).
FR FL RR and RL each x 2 conductors (+ and -) makes your 8 wires.
edit: If you take a good set of RCA's and snip off a plug, you will see the two conductors
Old Dec 25, 2005 | 03:49 PM
  #100
Tatanko's Avatar
Bacon Lover
I hope I understand this statement better when I see the PAC wiring/Pioneer wiring
Old Dec 25, 2005 | 04:05 PM
  #101
1996blackmax's Avatar
Wow this has been a very busy little thread .
Old Dec 25, 2005 | 04:46 PM
  #102
Tatanko's Avatar
Bacon Lover
Yessir it has I think those of us audio noobs who have been posting in it have learned a lot today.
Old Dec 25, 2005 | 05:05 PM
  #103
nismos14's Avatar
§è~® f®ÈÄk
For every noob there's always someone more noobie than you don't forget that.
Old Dec 25, 2005 | 05:20 PM
  #104
Tatanko's Avatar
Bacon Lover
Haha...I think I might put that in my sig
Old Dec 25, 2005 | 05:52 PM
  #105
nismos14's Avatar
§è~® f®ÈÄk
Lol be my guest
Old Dec 25, 2005 | 07:13 PM
  #106
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
I can get the harness for like $7 shipped off ebay. I'll be sure to get it. What kind of adapter?
None of that made any sense to me Like I said, I'm an audio idiot...gotta put it more simply for me. I also suck at wiring...so I'm looking at the simplest, least work-involved solution here.
1-Remove Door Panel
2-Remove screws from speaker pod
3-Remove Pod from door
4-Look at little section with amplifier.
5-see 4 wires
6-Clip the two that dont go to the speaker
7-Put new speaker in pod
8-Write the wire colors down
9-Put speaker pod back in, put door panel back on.
10-Repeat on other side.
Radio
1-When you look at the plug on the back of the radio you will note the wire colors you just wrote from the doors and rear speakers.
2-Plug these into the corresponding wires on the wiring kit (IE if you copied pink and green for the lef front, look at the wiring harness and the two wires that are left front get connected to the pink and green. So on and so on.)
Requires NO WIRING outside of clipping two wires and taping them at each speaker.
IE Like i said pics on my sounddomain.
Old Dec 25, 2005 | 07:24 PM
  #107
Tatanko's Avatar
Bacon Lover
Originally Posted by Cant_Get_Ryte
1-Remove Door Panel
5-see 4 wires
Radio
Ehh...I think I'll stick to just soldering a few wires when I get the PAC. I really don't feel like tearing all my doors apart again.
Old Dec 25, 2005 | 07:30 PM
  #108
nismos14's Avatar
§è~® f®ÈÄk
1-Remove Door Panel
5-see 4 wires
Radio
He's not replacing the speakers, only the headunit.
Old Dec 25, 2005 | 07:39 PM
  #109
Tatanko's Avatar
Bacon Lover
I was going to say...the step about "put new speakers in" made me go
Old Dec 25, 2005 | 08:33 PM
  #110
Nissan 6's Avatar
This is exactly why I took Circuit Citys free installation offer with any HU bought from them because I didnt want to mess around with the BOSE system!
  #111
NewEngSurf's Avatar
Hey guys , this thread has been pumpin today huh, i just went to the movies and another page has been added
Since us audio noobs are gettin so much attention might as well jump in with another question
When using the PAC and the original bose speakers, will the 40 x 4 watts from my alpine be powering the speakers or will this watage not be used and the alpine will simply signal the bose amps and turn them on and power the speakers
Old Dec 25, 2005 | 08:36 PM
  #112
NewEngSurf's Avatar
1-Remove Door Panel
5-see 4 wires
Radio
Is this using the PAC?
Old Dec 25, 2005 | 08:58 PM
  #113
nismos14's Avatar
§è~® f®ÈÄk
Signal is supplied to the bose only. No amplification.
Old Dec 25, 2005 | 08:59 PM
  #114
nismos14's Avatar
§è~® f®ÈÄk
No this is not with the PAC. Without the bose speakers as well.
Old Dec 25, 2005 | 09:25 PM
  #115
Tatanko's Avatar
Bacon Lover
Figured as much.
Then again, if there was amplification, the speakers would probably blow, right?
Side note: I've made 43 posts today
Old Dec 25, 2005 | 09:36 PM
  #116
nismos14's Avatar
§è~® f®ÈÄk
Not necessarily they would be using the inputs as high level inputs which could still work as long as you don't turn it up too loud. Depends on how picky the bose amps are.
P.S. You post ***** you... what'd u do count'em?
Old Dec 25, 2005 | 10:00 PM
  #117
Black Maxima
Without that PAC adapter thing the volume will get loud quickly.
Old Dec 25, 2005 | 10:03 PM
  #118
nismos14's Avatar
§è~® f®ÈÄk
Depends on how you wire it.
Old Dec 26, 2005 | 06:57 AM
  #119
Tatanko's Avatar
Bacon Lover
Nahh...I just know I started the day yesterday with 1,987. My goal for the day was to reach 2000 posts. Guess I hit my goal
Old Dec 26, 2005 | 07:04 AM
  #120
nismos14's Avatar
§è~® f®ÈÄk
K lets see today I start at 6499 goal 6500 goal met.... lets see where my post whoring gets me
