HU Replacement and Bose Woes
Old 12-26-2005 | 09:52 PM
  #241
Pearl96Max's Avatar
I tend to get a bit irritable
Originally Posted by Tatanko
What'd you do, sneak over here and delete it from my phone?
Umm obviously it flew over your head...
Old 12-26-2005 | 09:54 PM
  #242
Pearl96Max's Avatar
So I can clarify...
I still have djfrestyl's phone #, too, so I'm good...
Old 12-26-2005 | 09:55 PM
  #243
Pearl96Max's Avatar
Originally Posted by nosidetrips
so the speaker leads could get out of phase by connecting like a + to a - or a green with white stripe to a green or something like that? Is that what you mean by wiring issue, or something more like an incomplete contact or bad wire??
im a little confused on what i should be looking for when i get in there in the morning..
Thats correct. Or wires touching each that shouldnt be.
Old 12-26-2005 | 10:23 PM
  #244
Tatanko's Avatar
Bacon Lover
Originally Posted by Pearl96Max
So I can clarify...
Trust me, I GOT IT
Old 12-26-2005 | 10:30 PM
  #245
Pearl96Max's Avatar
Ahhhh Okie
Old 12-26-2005 | 10:37 PM
  #246
nosidetrips's Avatar
alright WOO i got anxious so i went and fooled around with it.
The problem was the gain controls were too low for one, and also when i put the HU back into its space the wires were getting squished together and causing the distortion.
so i turned the gain controls up and fixed the volume problem, but was having trouble situating the wire harness and PAC in such a way that they didnt interfere... :-/ o well, at least i know the problem
Old 12-27-2005 | 08:10 AM
  #247
Tatanko's Avatar
Bacon Lover
Good, good...now I know that I need some sort of wire-spacing solution when I go to do mine. I hope to avoid a few headaches other people have had...
Old 12-27-2005 | 08:24 AM
  #248
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
MAYBE if your a good boy Ill let you come later tonight. Otherwise youll have to wait
NISMO
It is Finished...
Old 12-27-2005 | 09:07 AM
  #249
nismos14's Avatar
§è~® f®ÈÄk
Yea... I been bad
Old 12-27-2005 | 10:38 AM
  #250
Tatanko's Avatar
Bacon Lover
You know what's really funny...
...I got my Bose headunit to work just now
The POS is still getting replaced though
Old 12-27-2005 | 02:10 PM
  #251
djfrestyl's Avatar
Suspension Yoda
Wires can be bundled up as tight as you wanna put them. Just make sure BARE wires arent touching. Use butt connectors/crimp caps. If you don't have any, let me know and I'll MAIL you some.
Old 12-27-2005 | 02:28 PM
  #252
Tatanko's Avatar
Bacon Lover
I've got plenty of spare cash laying around to pick little things like that up should I run into any problems. I may not be audio savvy, but I know not to let bare wires touch. Momma didn't raise no fool
Old 12-27-2005 | 02:41 PM
  #253
djfrestyl's Avatar
Suspension Yoda
Wish I had plenty of spare cash lying around.
Tell you what. You mail me that, and since you have plenty, I'll mail you nothing in return.
Old 12-27-2005 | 02:45 PM
  #254
Pearl96Max's Avatar
Blah just Paypal it over to me.
Old 12-27-2005 | 03:06 PM
  #255
Tatanko's Avatar
Bacon Lover
By spare cash I meant like $50...which is a lot relative to the price of tiny little things like butt connectors
Old 12-27-2005 | 03:35 PM
  #256
nismos14's Avatar
§è~® f®ÈÄk
Well guys I am officially Arc equipped now
Old 12-27-2005 | 05:15 PM
  #257
Pearl96Max's Avatar
Depends on how much you need. I spend about 5 times that a month on misc parts...
  #258
Pearl96Max's Avatar
Bout damn time, and if your gonna call...ya need to leave a message.
Old 12-27-2005 | 05:43 PM
  #259
djfrestyl's Avatar
Suspension Yoda
Haha I just saw this.
Quoted from page 1:
/thread
Old 12-27-2005 | 06:27 PM
  #260
FFxI30's Avatar
Sounds like a wiring issue. If any of the speaker leads are out of phase this can happen. Ive never used a PAC unit and I never will. Never had a complaint from a customer, especially when theyre saving $50+.
PearlMax, you said you never use the PAC unit. What do you use instead?? I guess I missed it in the past 9 pages.
Thanks for the help man.
Old 12-27-2005 | 07:01 PM
  #261
NewEngSurf's Avatar
By splicing RCA cables from the back ur headunit to the speakers wires on the bose harness
Nismo i got this right , right?
No need to by the PAC or an aftermarket harness?
How bout a power antenna adapter thingy?
Old 12-27-2005 | 07:37 PM
  #262
djfrestyl's Avatar
Suspension Yoda
Correct, splice in RCA's
No need for any harnesses except $3 worth of RCA's that you will snip anyway.
You will always need an antenna adapter with an aftermarket HU.
Old 12-27-2005 | 07:46 PM
  #263
NewEngSurf's Avatar
I thought that was correct, however, wouldnt there be 8 speaker wires, 4 speakers each having a + and - wire, so how would u just twist 4 of them together and then connect them to one of the RCAs, and then again to the other?
Old 12-27-2005 | 08:50 PM
  #264
Tatanko's Avatar
Bacon Lover
Quoted from page 1:
Yes, funny isn't it
Old 12-27-2005 | 11:04 PM
  #265
nismos14's Avatar
§è~® f®ÈÄk
Ya I know it was just a silly q about the Arc. I was wondering about the bridged/L+R/stereo switches and how to set the switches with a 4 channel input (fronts + sub) But I figured it out. It sounds good. I think I need to play with the tunning quite a bit though. All in all a very nice and clean sound. Bass reproduction is very good. Next step will be a new set of matched components up front when I get REALLY tired of whats up front, for now I'm good
Old 12-28-2005 | 10:40 AM
  #266
djfrestyl's Avatar
Suspension Yoda
If you have 4 RCA's (Front AND Rear) channels, then you will have 4 rca x 2 conductors= 8 wires.
Old 12-29-2005 | 12:19 PM
  #267
NewEngSurf's Avatar
Well i went with an adapter and it worked out great. Went to a local car audio store and they had everything i needed. Bose adapter, wiring harness, antenna adapter, and dash fittings. The dash fittings where made by metra and took a little custom work but it looks great. The bose speakers sound good if not better, however the high pitched "s" in some songs comes in a little bit distorted, hard to explain. Now i ran into a new problem, i push the BAND button on my apline headunit to switch from cd --> radio and i get nothign, CD keeps playing , and the radiostations do not appear on the screen. When i was plugging in the antenna to the back of the headunit i remember hearing my antenna come up, and i know i connected the power antenna wire together on the wiring harness. What is up? could that button just be busted? i really dont want to rip my dash apart again
Old 12-29-2005 | 12:52 PM
  #268
nismos14's Avatar
§è~® f®ÈÄk
You have to press the source button, not the band button.
Old 12-29-2005 | 01:45 PM
  #269
NewEngSurf's Avatar
i <3 nismo
Old 12-29-2005 | 02:21 PM
  #270
nismos14's Avatar
§è~® f®ÈÄk
I guess that fixed it?
6spd4dsc
05-09-2022 01:30 PM
AnsonJ
06-02-2017 02:35 PM
MikesChevelle
Audio/Video/Electronics
09-11-2016 07:36 PM
melteye
05-16-2016 01:02 AM
Maxinesdaddy
08-22-2015 12:43 AM
