How to stop this noise.....?
Old Jan 9, 2006 | 06:08 AM
02MaxGLE's Avatar
I have two 12s in the trunk. I have the rear plate coated pretty well where I don't have any rattle. Yet inside...the damn rear brake light cover rattles TOO damn much. To the point sometimes it sounds like I have a rattle box, so I turn it down. I dont want to put any dynamat inside of it and have the light torch it. Any ideas...?
Old Jan 9, 2006 | 10:04 AM
1996blackmax's Avatar
I have actually put dynamat inside mine. Once I took it apart I was able to see the problem spots. I put dynamat on it and it took care of it. I did not put inside where the bulb goes, just on the housing. My car is a 4th gen, but it may work for you.
Old Jan 9, 2006 | 10:10 AM
02MaxGLE's Avatar
I will be trying that...>thanks!!!
Old Jan 9, 2006 | 10:15 AM
Glad I could help .
Old Jan 10, 2006 | 01:13 AM
ShRapNeR's Avatar
i took mine out
plan on recovering the rear deck sometime this summber and covering up the hole..
Old Jan 10, 2006 | 08:44 PM
myer84's Avatar
I have a 6th gen and I removed the back panel and added Dynamat on the inside part of the deck. I did remove the speakers in order to lay it out cleaner. I removed the brake light housing and covered it and made a hole big enough to feed the harness that connects to the brake light. U will be surprise how good ur stock speakers are going to sound after doing that. I got the Bose speakers and damm they sound good.
Apr 16, 2020 05:15 AM
D Mason
Jun 21, 2016 04:43 AM
BobTX10
Oct 7, 2015 08:43 AM
maxima297
Sep 30, 2015 03:32 PM
foodmanry
Sep 24, 2015 12:02 PM
