I need Help choosing a killer setup.
Old Jan 12, 2006 | 05:01 PM
  #41
japmaxSE's Avatar
Go Get a Life!
So with my EQ having a professional tune it wont be a prob right?
Those Subs Manufactures SlickRick mentioned will do the job. If I want to hit over 130db's it is possible with the proper amp which would be the next step.
I think I'm covered as far as Drivers go. I think finding an amp that's flexible enough to give the driver enough mid to low bass at it's optimum would be nice and not overated.
Old Jan 12, 2006 | 05:02 PM
  #42
AscendantMax's Avatar
dual spiders simply means they the sub uses 2 spiders instead of 1. it suppose to help keep the cone linear at high excursion levels. but Dan Wiggins at Adire Audio made a comment stating using more than 1 spiders isn't always the best option. More is not always better.
XBL2 is adire's trademark motor technology. want more info? here's a good read from the man himself.
http://forum.carstereos.org/t56398-d...hnologies.html
Old Jan 12, 2006 | 05:03 PM
  #43
it's pretty damn easy to hit over 130. my 15 in a sealed box being powered by a small 300 watt amp hit 137 dB on the new Termlab mic.
(but my current sub amp puts a lot more than 300 watts )
Old Jan 12, 2006 | 05:17 PM
  #44
japmaxSE's Avatar
Go Get a Life!
Here is a good Audio Reference Site explains all the terminology's.
http://www.rane.com/par-s.html
Old Jan 12, 2006 | 05:19 PM
  #45
slickrick's Avatar
130db can be achieved so easily. I am unaware of what you want from your system. you tell stories of 4 18's and you want high spl from inaudible levels to barely audioble levels, then want a system that can hit in thr 130's?
Old Jan 12, 2006 | 05:23 PM
  #46
japmaxSE's Avatar
Go Get a Life!
Damn that easy,
Ok give me a speaker that will take me up toward 160db's plus all day long.
Will the 2 Mag D2's accomplish this? Or the XXX's? RE's?
Basically guys I want the Best I have the money to spend I want to be able to go to a DB show if I want and hit over 160db's...
Old Jan 12, 2006 | 05:32 PM
  #47
japmaxSE's Avatar
Go Get a Life!
Difference between XBL and new coil technologies?
1. Power handling: LMT, Split Coil, XBL²
2. Stroke: 3 way tie
3. Scalable from tweeters to big woofers: XBL², Split Coil, LMT
4. Low moving mass: XBL², Split Coil, LMT
5. Low inductance: XBL², Split Coil, LMT
6. Accepts shorting rings easily: XBL² Split Coil/LMT (tie)
7. Tolerance to winding errors: XBL², LMT, Split Coil
8. Motor Size: XBL², Split Coil, LMT
9. Flux Usage Efficiency: XBL², LMT, Split Coil
10. Production Cost: XBL², Split Coil, LMT
11. Production Ease (need to change production methods): XBL², Split Coil, LMT
Old Jan 12, 2006 | 05:33 PM
  #48
slickrick's Avatar
lol, a speaker? try about 8-12 speakers maybe plus multiple batteries, electrical upgrades, a new car, etc.
Old Jan 12, 2006 | 05:34 PM
  #49
slickrick's Avatar
3 db's=twice as loud...so 160 is not feasbile in a maxima let alone driveable at that high of a DB.
Old Jan 12, 2006 | 05:40 PM
  #50
160 dB? you DO realize how high of a number that is right? took my friend four RE MT 15s and several kilowatts to hit 155 db in his explorer...
Old Jan 12, 2006 | 06:09 PM
  #51
japmaxSE's Avatar
Go Get a Life!
This is exactly what I want to do to my doors and mess up my girlfriends hair.
http://www.dbdragracing.nl/movies/au...ies/truck1.wmv
Old Jan 12, 2006 | 07:12 PM
  #52
that's nothing.
http://www.realmofexcursion.com/vide...dio/mt15.5.wmv
Old Jan 12, 2006 | 07:17 PM
  #53
PandaXpress's Avatar
bwhahaha..gordon for the KILL!
Old Jan 12, 2006 | 07:21 PM
  #54
whlimi's Avatar
Damn that easy,
lol
Do you want to have a heart attack? There are cheaper ways to do that.....
160dbs for everyday driving is overkill not to mention that you're going to need insane amounts of power and air movement to accomplish that. I bet you'll be happy with something like 140db.
Old Jan 12, 2006 | 07:27 PM
  #55
Pearl96Max's Avatar
I tend to get a bit irritable
This thread isnt serious is it????
Old Jan 12, 2006 | 07:30 PM
  #56
i'm afraid so Don
  #57
japmaxSE's Avatar
Go Get a Life!
Originally Posted by whlimi
lol
Yes I do nah but yeah I don't really know what 160db's sounds like but I know you can't sit in something that produces that high of a DB. I just want that option on tap when ever I want to...
Damn the RE series along with the XXX is tempting as well..
Old Jan 12, 2006 | 07:31 PM
  #58
Pearl96Max's Avatar
i'm afraid so Don
What a shame.....
Old Jan 12, 2006 | 07:33 PM
  #59
Pearl96Max's Avatar
Ok, well then lets get started. You have about $10K laying around right? You did say money isnt an option, so confirm the money first. Also remember this $10K is a STARTING point. It will be more.
Old Jan 12, 2006 | 07:34 PM
  #60
japmaxSE's Avatar
Go Get a Life!
I'm just as serious about this as much as the 3.5 swap..
I know I sound like a Newbie here but I'm really serious about doing this I already made arrangements next weekend to get the Box custom made.
Old Jan 12, 2006 | 07:35 PM
  #61
just do this. get a 15" xxx. build a BIG **** box, and have the port vented into the cabin via the rear deck. feed that thing ~1500 watts.
if that's not loud enough, then come back to us for more options.
Old Jan 12, 2006 | 07:39 PM
  #62
japmaxSE's Avatar
Go Get a Life!
I already spent $1700 including labor it's going into the Headunit and door panel speakers alone. Now I have about $2K for the subs and amps including labor. I just need to figure what amp and sub to use.
So that's why I'm here and trying to see what's out there before next week, so I don't sound like a fool at the shop.
Old Jan 12, 2006 | 07:42 PM
  #63
Pearl96Max's Avatar
$2K is a decent amount of money for a sub setup, although it will not in ANY way get you to 160+ Ever.
Old Jan 12, 2006 | 07:43 PM
  #64
Pearl96Max's Avatar
$1700 for a HU and door speakers? Please enlighten me here.
Old Jan 12, 2006 | 07:46 PM
  #65
$2k will get you in the high 140s, possibly low 150s if done correctly. but realize you will not have a trunk left. 160 is out of the question.
140 is PLENTY loud IMO...
Old Jan 12, 2006 | 07:48 PM
  #66
Pearl96Max's Avatar
Its not even the equipment that would be uber expensive it would be primarily the power to run the equipment.
Old Jan 12, 2006 | 07:51 PM
  #67
i got a feeling that shop will try to sell him some 'caps'
Old Jan 12, 2006 | 07:52 PM
  #68
Pearl96Max's Avatar
Buahahahahahahaha Audiobahn bling bling FTW !!
  #69
Pearl96Max's Avatar
BTW Gordon, I have some Rainbows callin your name now....
Old Jan 12, 2006 | 07:54 PM
  #70
the ACS?
Old Jan 12, 2006 | 07:59 PM
  #71
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
box built w/o the subs being selected? what specs is it built too?
Old Jan 12, 2006 | 08:01 PM
  #72
japmaxSE's Avatar
Go Get a Life!
My best Friend is into all this Car Audio stuff. I gave him the money to get me the goods. He's the one doing the whole job. I have no idea yet what he has in planned for the head unit and door panel speakers but I trust him and I know he's going to give me the right stuff. He told me their's so many sub's out there he won't have an answer for me till next week. So I'm trying to get some ideas here.
AscendantMax $2k will get you in the high 140s, possibly low 150s if done correctly. but realize you will not have a trunk left. 160 is out of the question.
Yeah you might be right what do I know.
But once again thanx guys for the input I'm just a little excited listening to all these subs on goggle and all. Sorry for the stupid comments but yall understand I'll just have to wait till next week and just do some reading for now.
Old Jan 12, 2006 | 08:05 PM
  #73
no hard feelings
just saying you want 160 daily will take some work. so we sorta flamed away
Old Jan 12, 2006 | 08:09 PM
  #74
Pearl96Max's Avatar
Well hell if you blindly hand out close to $2K you should be shopping with me. At least you know for the most part youll be getting upper shelf equipment.
Old Jan 12, 2006 | 08:10 PM
  #75
Pearl96Max's Avatar
the ACS?
Nooooo Actual Rainbows...Profis,Profi Vanadiums, hell I even have a set of Platinums.
Old Jan 12, 2006 | 08:49 PM
  #76
how much are the profis and the vanadiums...
Old Jan 12, 2006 | 08:53 PM
  #77
Pearl96Max's Avatar
we can talk....
Old Jan 12, 2006 | 09:05 PM
  #78
Chocolate_Boi_1Der
that was my point exactly...
Old Jan 12, 2006 | 09:12 PM
  #79
slickrick's Avatar
oy vey...I'm sorry but i would not shell out 1.7k for a H/U and door panels to a buddy building me a custom box for no subs yet.
Old Jan 12, 2006 | 11:13 PM
  #80
we can talk....
somewhere in the realms of the up6 price range perhaps?
