What to do with a 5-channel amp?
Old Jan 14, 2006 | 09:18 AM
doomtoo's Avatar
I bought a 5 channel amp awhile ago since the stock bose amplifiers were dying- so replaced them with one 5channel amp in the back with a sub. I've upgraded the radio, so now I actually have more than enough power going to the speakers, but should I leave it that way, or is there a way to channel more power to the sub?
Currently it's set up this way: 4*75W to speakers, 1*200W to sub.
The sub sounds pretty good (ported enclosure, creates alot of bass), but any way to wire everythign up that will sound better?
Currently it is HU-> AMplifier via RCA's, -> speakers and subs via speaker wire. Also, the HU has an option to control the sub independently, but currently the sub isn't connected to the HU directly.
Old Jan 14, 2006 | 10:08 AM
Pearl96Max's Avatar
I tend to get a bit irritable
Run another set of RCAs to the amp from the HU. Keep the amp and everything else the way it is.
Old Jan 14, 2006 | 10:10 AM
Bluesbrekr's Avatar
Doctorate in Detailing
By any chance is your amp a USAmps 5600? That's what I have and I love it. I have the OEM non Bloze HU. I used 2 converters off the back of the HU to run to the amp in the trunk. Then speaker wire back to the OEM wire in the dash. (not the best set up, I know) I have Eclipse components in the front and Infinity Reference coax in the rear. I have a DVC sub running at 2 ohms wired direct to the amp (@2 ohms the amp pushes 300 watts)
One way for it to sound better would be to get a sub running at 2 ohms and use the amp to push the 4 cabin speakers, rather than running them off the HU.
Old Jan 14, 2006 | 10:16 AM
Pearl96Max's Avatar
Thats IF he has the amp your referring to and IF he doesnt already have it that way.
I believe from his post his interiors Are running off of the amp.
Old Jan 14, 2006 | 10:24 AM
Bluesbrekr's Avatar
True dat.
You said run another set of RCA's to the amp. What will this do?
Old Jan 14, 2006 | 10:30 AM
Pearl96Max's Avatar
Itll give him sub control via the radio.
Old Jan 14, 2006 | 10:32 AM
Bluesbrekr's Avatar
Got it. I'm still a noob when it comes to ICE.
Old Jan 14, 2006 | 10:53 AM
Pearl96Max's Avatar
Its all good. Gotta start somewhere.
Old Jan 14, 2006 | 12:26 PM
djfrestyl's Avatar
Suspension Yoda
Usually the HU has separate preout signals for front/rear/sub. This is why you want to run another set of RCA's for the dedicated sub input that the amp should have.
Old Jan 14, 2006 | 01:13 PM
Pearl96Max's Avatar
asked and answered already peckerwood.
Old Jan 14, 2006 | 03:59 PM
djfrestyl's Avatar
Suspension Yoda
Thanks Focker. Just clarifying a little bit more.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
