Power cable splice?
Old Jan 28, 2006 | 09:41 AM
DR0832's Avatar
Power cable splice?
I had a 2 channel amp under my seat powering my component speakers and I had my car detailed and the idiots got the amp soaked and it got short circuited. I bought a new amp to replace which I though were be a perfect match to swap out however its larger than the other amp and the current 4 gauge power cable is now about 3-4 inches too short to do a direct swap. Somebody else installed my amp for me and I am not very technically inclined to go through and install a new cable. Is it possible for me to somehow buy something to splice a 4" piece of power cable to the end of the current cable, possible with some sort of connector or something? If so where can I buy this sort of thing?
Old Jan 28, 2006 | 10:07 AM
AscendantMax's Avatar
you can get a AGU fuse holder like that one and connect your wires that way. you sure there's no more slack on the line?
Old Jan 28, 2006 | 10:26 AM
DR0832's Avatar
Actually yes there was enough slack to get it installed. However I thought it would be a direct swap but unfortunately I am not getting any sound from the speakers. I have a feeling this has something to do with the crossovers but I can't even remember where they were installed.
Old Jan 29, 2006 | 09:17 AM
myer84's Avatar
This is a cheaper solution. Its about $4-$5. The only thing u need to do is cover it with tape or shrink tube to avoid any ground contact. I had to do the same on my project.
Old Jan 29, 2006 | 08:34 PM
djfrestyl's Avatar
Suspension Yoda
4 guage coupler would be my suggestion too. Although, if you are planning on going back to that detailer, that AGU fuse holder that Gordon suggested would be ideal
gigabyte
Jan 6, 2017 06:05 PM
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
