Affordable Amp
Old Feb 22, 2006 | 09:19 PM
KFL's Avatar
KFL
Affordable Amp
Looking for a good affordable amp to run a kicker solob. 10"
I believe the specs were 600watts 2ohm mono.. I've had this sub for 2years+ but it's been sitting around collecting dust.
Curious
1-I once tested to see if it would work with a 2channel amp it actually worked..was this bad?
2-Should I go for close to 600watts as possible. The sub is actually a tad overkill half the amount would suffice 300watts.
3-Whats a good amp?
Old Feb 22, 2006 | 09:20 PM
slickrick's Avatar
whats your budget? check out pearl96max he is a dealer and in NJ.
Old Feb 22, 2006 | 10:08 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Budget would definately help. Im assuming that its a dual 2Ohm sub?
Old Feb 23, 2006 | 07:13 AM
maxmale's Avatar
decent cheap amp = kenwood
Old Feb 23, 2006 | 07:14 AM
maxmale's Avatar
i had 12" solo l7 pushed hard by a kenwood excelon kac x810d
Old Feb 23, 2006 | 07:15 AM
maxmale's Avatar
i have a kac-9152 still in the box i'll get rid of for 250. never used, not refurbished.
Old Feb 23, 2006 | 08:11 AM
nismos14's Avatar
§è~® f®ÈÄk
Curious
3-Whats a good amp?
Whats up man? That sub, if its the round version is actually only 300 rms, so you would want a good quality amp that can put out at least 200 rms but closer to 300. The sub or the manual for the sub should say what voice coil configuration it has. Once you find that out, you can narrow down whether you'd rather have a 1ohm stable amp or a 2 ohm stable amp. Also did you figure out the components?
Old Feb 23, 2006 | 11:59 AM
KFL's Avatar
KFL
I have a kicker amp actually 600.1 it died for some unknow reason, Removed cover nothing looks fried. I looked around locally to get it repaired a while ago no dice.Kind of sucks since I paid 300+ for it way back when..I do need to get a smaller box as well. Yeah Nismos14 got them installed, just going with 1 tweeter for now. don't feel like chopping door panel. Hm budget varries.. I have to get car painted next month. So sub 250, lower the better or If
anyone knows of aamp repair shop in central NJ have it looked at,fixed if possible.
http://home.comcast.net/~kfl007/amp.jpg
http://home.comcast.net/~kfl007/ampi.jpg
http://home.comcast.net/~kfl007/box.jpg
http://home.comcast.net/~kfl007/hu.jpg
Old Feb 23, 2006 | 01:32 PM
nismos14's Avatar
§è~® f®ÈÄk
I think Doug knows of some places for repair cant_get_ryte pm him and see if he knows.
Old Feb 23, 2006 | 01:35 PM
nismos14's Avatar
§è~® f®ÈÄk
Do the lights still come on on the amp? does it show protection mode? Are you sure the sub is still functioning? I dont think the place Doug knows is local though its cheaper to send it for repair than to buy a new amp.
Old Feb 23, 2006 | 01:41 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
he does and will only post the info for food
Old Feb 23, 2006 | 01:50 PM
nismos14's Avatar
§è~® f®ÈÄk
Old Feb 23, 2006 | 01:52 PM
MannyNJ2k2max's Avatar
PM/EMAIL 'Polecat' in this forum...Tracy works for Kicker, will get that thing repaired no prob.
Thats actually a pretty beefy amp, sounds like you got a dud.
Unless of course you were running THAT sub with that amp presenting a 1ohm load, then i can understand how it went poof..
Old Feb 25, 2006 | 09:07 PM
Fast1one's Avatar
Agreed...my old one never have me problems...
Old Feb 25, 2006 | 09:58 PM
slickrick's Avatar
that would not surprise me...
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
