Need some fast help...
Old Feb 26, 2006 | 12:08 PM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
Where in the hell do you route the wires for the front door speakers? I had no idea that the stock speaker wire turned into a plug. Do I need to drill a hole somewhere?
Old Feb 26, 2006 | 12:13 PM
technogeeky's Avatar
You can:
1. use the speaker wires already installed
2. remove the 'harness' (and maybe the whole door too...) and find the small hole BEHIND the harness (it's between the harness and the front of the car). Run it thru there.
Old Feb 26, 2006 | 12:18 PM
1996blackmax's Avatar
Just feed the wires through to the inside of the door and car. You may need to cut a small slit in the grommets on the car side and door side. No need to take the door off. I can just imagine the pain in the rear it would be to align the door back up.
Using the stock speaker wire...will this not affect the performance of my new speaker?
Old Feb 26, 2006 | 12:19 PM
It was actually pretty easy
Old Feb 26, 2006 | 12:20 PM
It depends. If you are using a component set, then you'll need to account for the wire(s) running to the tweeter in the A-pillar. I don't know where they go to, but I just ran new wires.
I don't think the wires are too small - it's just a matter of how they are run.
Old Feb 26, 2006 | 12:21 PM
I am running components
Old Feb 26, 2006 | 12:30 PM
Easier to just run the wires vs. run wires and put door back on .
Old Feb 26, 2006 | 03:16 PM
djfrestyl's Avatar
Suspension Yoda
1996blackmax, he's running a 5th gen which has a Molex plug. can't just run into the doors.
You can drill a small hole through the firewall, and then feed it into the door, or just use stock wiring. For just a component set, you will be fine. It's only when you go into very incredible SQ setups that inferior speaker wiring (for such a short length) is a detriment.
Old Feb 26, 2006 | 03:30 PM
BIG OOPS! Not good to type and hold the little one I guess .
The (me)
was today.
Old Feb 26, 2006 | 06:07 PM
Thanks guys, I found the grommet and then made a slir through the stock tubing through the door. Good to go now.
Old Feb 26, 2006 | 09:08 PM
djfrestyl's Avatar
Suspension Yoda
How did u get it out of the car?
Old Feb 28, 2006 | 11:16 AM
Well , I had to get underneath the steering column and work it through a bunch of wires. It took some time but it's all good now.
lrb6805
Sep 30, 2015 08:12 AM
msellas
Sep 23, 2015 09:16 PM
220k+ A32
Sep 23, 2015 03:38 PM
pears
Sep 18, 2015 05:25 AM
