Wiring Up the Viper 791XV to Open Trunk
Old Mar 2, 2006 | 03:04 PM
siren001's Avatar
Hey,
I got a question, I have got the 791XV installed in my 01 max. and I was wondering how would go about wiring it up so that you can open the trunk off the remote.
What wires would I need to tap into, I could open the trunk off of the old stock "alarm" but the new on cannot.
The car audio place said it would be $50 to wire up the trunk, I know the selenoid is already there from the stock one.
Thanks.
Old Mar 2, 2006 | 03:28 PM
djfrestyl's Avatar
Suspension Yoda
You need a relay, which is like $2-3 from Radio Shack.
Trunk/Hatch Pin is purple/yellow located at pin 38 at SECU
If you do not know what you are doing I highly suggest getting a trained professional to do it, as tampering with your alarm MAY void the warranty.
edit:
Trunk/Hatch Release wire is blue, located at pin 12 at SECU
I'm not sure which of these to use.
Old Mar 2, 2006 | 04:41 PM
siren001's Avatar
Which wire would you use off the alarm.. I know the one on the ECU but not the alarm.
Old Mar 2, 2006 | 04:44 PM
kpr10is's Avatar
Youd use the Trunk/Hatch Release wire, blue, pin 12. I second the motion for a professional install, and the fact that they charge an extra 50 is crap.
Heres relay wiring info for what you'd do if you feel so inclined.
85-12v
86-red/white wire from alarm brain, aka channel 2 output.
87-(empty)
87a-ground
30-output to blue trunk release wire in car.
Miket2006
Mar 1, 2021 03:55 AM
mrgooch
Sep 21, 2015 08:43 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
rbaker100
Sep 6, 2015 02:46 PM
