installing indash DVD player
Old Mar 9, 2006 | 07:50 AM
Irish's Avatar
This is a democracy
for those of you have installed an indash dvd player, i have a few questions. there are a few wire that i havent seen before. there is a Brake wire and then also a back wire, both seem to be need to connect and get the player to work. any suggestions would be help
irish
Old Mar 9, 2006 | 08:15 AM
myer84's Avatar
Ok buddy im kinda having a little trouble understanding u, but what i can understand is that u have a black cable and an e-brake cable right? Well both should be connected otherwise ur dvd player wont work. They do this in order to avoid people to drive and use dvd functions at the same time. Tell me wht kind of dvd player is this? I have a pioneer and didnt connect mine to the e-brake. I just connected the wire to a switch and ground (no power). With this I trick the HU to think i'm in park mode. I would check around first though because some DVD players are different and might need to connect urs diferently if u want to bypass the safety feature. The other cable(blk) should be grounded.
Old Mar 9, 2006 | 08:55 AM
mendon99's Avatar
tastey wheat
is it a microvision indash? if so check this thread:
http://forums.maxima.org/showthread.php?t=455920
my guess is the black is ground. what are the other wires attached?
edit: did you mean 'black' wire? or 'back' wire?
Old Mar 9, 2006 | 02:29 PM
Irish's Avatar
This is a democracy
irish
back wire.....
Old Mar 9, 2006 | 09:22 PM
mendon99's Avatar
tastey wheat
ya, i see it. i wasn't sure if it was a typo..
im not understanding what you mean by "back wire" then.
theres only one? what color is it? is it like a single 20 awg-ish wire? or an RCA? need more info. also never said if you had a microvision or not..
Old Mar 9, 2006 | 09:53 PM
Irish's Avatar
This is a democracy
which wire is it on the 4th gen ebrake that goes to the ebrake sensor?
Old Mar 9, 2006 | 10:12 PM
mendon99's Avatar
tastey wheat
if you unbutton your ebrake boot, you will see a nut there, it holds onto the ebrake cable. you can attach the wire to that..worked for me.
Old Mar 9, 2006 | 10:14 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Without knowing what kind of DVD player it is its kinda hard to help. Although typically if you want to watch video while the car is running/ebrake off then you should just ground the brake wire.
"Back" wire is most likely for a backup camera activation. Although Again...we dont know what kind of unit this is...
MaxLife17
Jun 27, 2019 01:37 PM
t6378tp
Sep 29, 2018 04:27 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
