Wiring led's?
Old Mar 16, 2006 | 04:33 PM
skierxx5556's Avatar
Wiring led's?
Hey guys I just bought a bunch of led's and I have a few quesions. What side is pos and neg? What side does the resistor go on?
Old Mar 16, 2006 | 07:38 PM
Anyone????
kpr10is's Avatar
wheres metal maxima to answer this?
oh yeah, banned! LOL
Old Mar 17, 2006 | 07:41 AM
D Love's Avatar
AGAIN!?! That guy is always getting banned! lol
Positive side is the side with the longer lead. Doesn't matter which side the resistor is on. You might also want to reference this thread.
Old Mar 17, 2006 | 10:10 AM
MacGyverS2000's Avatar
The short lead (cathode) goes to ground, also look for a flat spot on the body that also indicates the cathode (though this is not always there). If the leads have been cut, you can also look at the metal inside the body (assuming it's clear and not a milky package)... the larger "bowl" side is typically (99% of the time) the cathode. You can also use the diode check function of most multimeters to determine proper orientation... in the correct direction you will see a forward voltage displayed, incorrect orientation and the voltage will be near zero or the display will show nil/error/whatever.
That should give you enough methods to check against
And it doesn't matter what side the resistor goes on, but standard convention puts the resistor on the most positive side (i.e., between the battery and LED, rather than LED and ground).
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
