**The Audio Thread**
Old May 12, 2006 | 06:32 AM
  #361
k3v's Avatar
k3v
well the speaker box only has one set of speaker inputs, so im guessing they wired 2 8 ohm subs in parallel to get 4ohm, so i would need something that gave 400Wx1 @ 4 ohms. correct? also i would prefer to buy it in a store with some kind of warranty and not from people online. i have done some reasearch and it looks like this http://www.crutchfield.com/S-NgChccl...20&I=489AP1200 might be a good amp for my subs. what do you all think?
Old May 12, 2006 | 06:51 AM
  #362
nismos14's Avatar
§è~® f®ÈÄk
Better verify what the resistance is on the subs. Profile amp...
Old May 12, 2006 | 07:03 AM
  #363
k3v's Avatar
k3v
yea im positive its 4 ohm because the book that came with it said so. and i know profile isnt all that great. but what else can i get that pushes that many watts for that price? and at least all the reviews were good. is profile really that bad?
Old May 12, 2006 | 07:38 AM
  #364
AscendantMax's Avatar
i'd look into hifonics. not the best of amps, but they're relatively cheap and put out decent amount of power.
Old May 12, 2006 | 09:26 PM
  #365
WhiteMaxima9600's Avatar
Yeah it's a 400x1 @4ohm amp, I was just figuring roughly what it would put out wired 8ohm.. I was thinking if you were to wire them both in series then parallel to the amp you would get 200watts to both subs @4ohms right? This is with the amp bridged.
Oh i forgot profile amps have a 3yr. warranty, that's impressive i guess.
Old May 14, 2006 | 08:39 AM
  #366
So, finally got everything connected and tuned. Only listened for about 15 minutes or so, but for those 15 minutes I was smiling non-stop . Midbass is nice, vocals are natural and warm, and the highs are defined without being harsh. I have the tweeters at +3 dB on the crossovers, (you can have it at 0 dB, +3 dB, -3 dB, or -6 dB.) I have the gains set so that they are receiving 100 watts per side. I will give a better review at the end of today when I have obtained more listening time, but so far, it's money well spent!
Old May 14, 2006 | 10:11 AM
  #367
djfrestyl's Avatar
Suspension Yoda
Took you long enough...
Old May 15, 2006 | 05:46 PM
  #368
SpeedyBlue's Avatar
I just finished the install of an amp and sealed box w/ 2-10's. Now I have an aweful vibration on the rear deck. What is the cure?
Old May 15, 2006 | 05:54 PM
  #369
deaden the crap out of it.
Old May 15, 2006 | 05:58 PM
  #370
SpeedyBlue's Avatar
What do you suggest using and about how much? Do I put the deadener under the deck on the fabric or do I put it on the metal?
Old May 15, 2006 | 06:47 PM
  #371
djfrestyl's Avatar
Suspension Yoda
Tar based deadening on the metal. Foam based deadening under the deck (the "fabric")
Robert Schneeweis
Jan 11, 2017 06:47 PM
Fbana41
Aug 29, 2016 12:18 PM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 20, 2015 10:20 PM
popdedop
Sep 11, 2015 11:17 AM
