hissing in tweeters
Old Apr 20, 2006 | 06:33 AM
Torgus's Avatar
hissing in tweeters
any tips on how to remove the hissing sound in my tweeters when i turn up the volume?
Old Apr 20, 2006 | 06:37 AM
djfrestyl's Avatar
Suspension Yoda
Find the source of it.
Old Apr 20, 2006 | 06:38 AM
Torgus's Avatar
obviously. what are the possible sources.
Old Apr 20, 2006 | 06:43 AM
djfrestyl's Avatar
Suspension Yoda
HU, amp, grounds, speaker wire, RCA
Is this while using radio or CD?
Old Apr 20, 2006 | 07:27 AM
Torgus's Avatar
cds. it's an eclipse HU, all rcas are run with speaker wire but on the other side of the car from the power. all speaker wire is 14guage. i'v check all the physical connections...
maybe i'll reground the amps. well give them seperate grounds. any other suggestions?
Old Apr 20, 2006 | 07:35 AM
Pearl96Max's Avatar
I tend to get a bit irritable
give us some detail on exactly what is in the car. Products as well as models.
Old Apr 20, 2006 | 07:38 AM
djfrestyl's Avatar
Suspension Yoda
Don't ground the amps separately. That's opening up a whole new can of worms.
Paint is scraped off the grounding point?
Old Apr 20, 2006 | 07:40 AM
TheBigDu's Avatar
Wait, seriously? Maybe that's my problem then. (I still have the hissing too.) What's wrong with grounding the amps separately?
Old Apr 20, 2006 | 07:48 AM
Pearl96Max's Avatar
I told you when you were here to share a ground. Using different grounding points can cause a loop.
Remember when I gave ya the wire I was seeing how far it needed to go for them to be together?
Old Apr 20, 2006 | 08:08 AM
TheBigDu's Avatar
Hehe, yes...?
I do remember, but the wires didn't work out to be long enough for where i put the ground point. I'll have to fix this as soon as I get a chance. Will this harm the amps in any way while I have them grounded separately? (because I don't think I'll be able to fix it until I get home in May)
Old Apr 20, 2006 | 08:11 AM
Pearl96Max's Avatar
no harm will come to the amps, youll be ok.
Old Apr 20, 2006 | 08:29 AM
Torgus's Avatar
cdt ef-61i components. tw-25 1inch tweeters, 560i crossover. powered by kenwood 4way amp. running bridges putting out 180rmsx2@4. but i have the gain all the way down on the amp becuase the speakers can only take around 140rms. i have a highpassfilter set at 80hz.
the other amp is a fosgate 150rmsx2@4 powering two JL w1 in a sealed box.
all the paint is scrapped off the ground. the ground is longer then 3ft because i'm using a distrobution block for both power and ground. i have 4guage power wire run to the 8guage distroblock.
the speaker wire is 14guage and is run next to the rcas. all the RCAs are relativly new and were bought from a car stereo shop. none of the RCAs are grounded.
currently i have the hu treble set at -6 and it still hisses. and if i increase it obviously the hissing increase as well.
edit:i guess i can switching the rcas 1st and if that doesn't help i'll switch the fosgate amp to the components and the kenwood for the subs when i get home...this hissing is driving me insane. No suggestions???
Old Apr 23, 2006 | 05:00 AM
ElVito1981's Avatar
Is it bad to ground an amp on painted metal??? Cause that's what I did.
Old Apr 23, 2006 | 05:02 AM
ElVito1981's Avatar
I used red anti-rust paint.
Old Apr 23, 2006 | 06:57 AM
Scope's Avatar
Im izz sexay
Yes it is simply because paint cannot transfer a strong signal. You MUST scrape off all paint or you can damage your amp since it's not properly being grounded.
Old Apr 23, 2006 | 07:15 AM
Torgus's Avatar
damn hijackers. why do my tweeters hiss!
Old Apr 23, 2006 | 08:37 AM
ElVito1981's Avatar
that's what i figured. Thanks!
Old Apr 23, 2006 | 09:45 AM
1996blackmax's Avatar
damn hijackers.
Old Apr 24, 2006 | 08:52 AM
djfrestyl's Avatar
Suspension Yoda
We are. Make a solid ground and we'll go from there. What have you tried thus far?
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
ericdwong
Jan 26, 2001 05:51 AM
metallic97gxe
Dec 5, 2000 07:40 AM
