Was this ever done, adding a sub in the BOSE “cutout”?
I have a none-BOSE system in a 5th gen and want to add a sub but do not want a box in the trunk. Even though my car is none-BOSE it has the “cutout” for the BOSE sub.
Did anybody install a sub were the BOSE sub goes? If so what kind of sub and size?
Originally Posted by LeX
what are tin snips?
you definitely have to trim the basket as most subs have a basket that is too wide to allow them to mount
They're like scissors, for metal.
OK, no need to gut any metal for an 8" sub. I used an 1/2" MDF ring, mounted that to the plate the Bose sub is on and then mounted the sub to the ring. You guys are making this too hard. If you want to go up to a 10" sub. Remove the stock plate the Bose sub is mounted on. Make a baffle out of 1/2" MDF and mount the baffle to the actual rear deck, then mount the sub to the baffle. Make sure the sub is designed to operate in an IB or free air installation.
That was going to be my second suggestion, I just realized that now. Much easier, and actually a better install because metal resonates much worse than MDF.
Originally Posted by Stalldaworld
does anyone have any pics of their open air set up in the rear deck? from the top of the rear deack and from in the trunk?
It looks like they got deleted. I will see if Kevin kept any. Also, PM SC2k1. I think he got a couple shots. He now has a DLS AO10 that replaced an ID8 and previoulsy a CDT CF8. Man I hope someone has those pics, it was nice.
Ah ha. That was worth every penny to become a donating member. Advanced Search owns.
Original thread. http://www.forums.maxima.org/showthread.php?t=421103
And a link to the install. http://community.webshots.com/album/413129787MZCqNm
I am glad they were still there.
Long long long ago I installed a Kicker FreeAir 8" sub in the rear deck where the bose sub was. I think it was a "F8c"
Anyways, in my case I didn't have to trim any metal...for the most part it just dropped right in. I didn't even have to take my rear deck out to install it.
But, I now have a 12" in a sealed box in the trunk if that tells you anything. I wasn't anywhere near satisfied with it. Perhaps if I made a better effort to seal the trunk...but I never went that far.
