Aftermarket HU + Metra 70-7551 = CRAP!
Old 04-26-2006, 07:28 PM
phong's Avatar
If anyone is considering "upgrading" your stock Bose system by replacing the headunit, DON'T! I used the Metra 70-7551 amplifier integration adapter and when I turned it on for the first time, it sounded horrible! So I figured I just needed to adjust the settings, but after fiddling with it for 10 minutes, the sound just didn't improve. At max volume, things got distorted, and there was absolutely no bass response. I threw in a CD for comparison and believe it or not, the stock Bose headunit sounded 10x better and louder.
I just finished packing the Alpine CDA-9857 up. I'm kinda disappointed because I really wanted to integrate my iPod, which was the whole reason I started this project. I hope Crutchfield doesn't mind I painted the install kit Titanium, ha!
Moral of the story: Replace all components or don't bother. Anything worth doing is worth doing right, I suppose.
phong is offline
Old 04-26-2006, 07:35 PM
Got Projectors?
MetaOrbit's Avatar
I don't know anything about the Metra kit you referenced but I know lots of people on here have been satisfied using aftermarket head units with bose using the PAC ROEM-NIS2 (myself included). I didn't have any of the problems you experienced.
MetaOrbit is offline
Old 04-26-2006, 07:53 PM
FriscoMaxima's Avatar
well, thank god i do not have bose...
FriscoMaxima is offline
Old 04-26-2006, 08:15 PM
slickrick's Avatar
ah yes somebody got it right!!! do it right the 1st time...and yes this means toss out everything that resembles Bose or anything stock audiowise in a maxima.
slickrick is offline
Suspension Yoda
djfrestyl's Avatar
What a generalized statement.
Something must have been done wrong, because there are MANY users that have done exactly what you have done with positive results. In fact, it's been argued that replacing your Bose HU with aftermarket makes the rest of the Bose system sound better.
djfrestyl is offline
Old 04-26-2006, 09:00 PM
I tend to get a bit irritable
Pearl96Max's Avatar
Hmm interesting. Ive been doing this for years and literally Several dozen Nissans with absolutely No issues whatsoever. Sounds like an installer error to me.
Pearl96Max is offline
Old 04-27-2006, 05:04 AM
§è~® f®ÈÄk
nismos14's Avatar
It's either you did something wrong or your HU is not capable of the right output. What is the output voltage of the HU? How did you wire up the rca's from the HU to the 70-7551?
Actually the output voltage shouldn't even matter. The bose only outputs like 1 volt anyways. Sounds like user error. My bose sounds GREAT with the aftermarket HU.
nismos14 is offline
Old 04-27-2006, 05:33 AM
SonicDust187's Avatar
I use the metra adapter and it worked great for me.
SonicDust187 is offline
Old 04-27-2006, 09:54 AM
I just got mine yesterday... it was a beeatch soldering all the commections...
Old 04-27-2006, 10:09 AM
§è~® f®ÈÄk
nismos14's Avatar
Soldering is so easy.
nismos14 is offline
Old 04-28-2006, 03:40 AM
phong's Avatar
Thanks for all the comments, but it definitely was NOT installer error. The important connections (the line-level rca preouts) are already done for you. The only ones left were power +/-, illumination, power antenna, and remote turn-on. I soldered all connections and heat-shrinked each individual wire. Even a monkey could get it right.
phong is offline
Old 04-28-2006, 04:18 AM
Pearl96Max's Avatar
Then a defective HU? Either way its been done for years with no issues.
Old 04-28-2006, 04:40 AM
§è~® f®ÈÄk
nismos14's Avatar
The majority of us who've done it have had no problems. Something is/was wrong there. Do you have another HU that you could try out?
nismos14 is offline
Old 04-30-2006, 10:10 AM
Peabo5000's Avatar
Hey I did the same thing. I have an 2003 Alpine 9807- with the volume turned all the way to 35; the sound i expected just isn't there for me either in terms of volume. But it sounds good just the bass kinda sux.
Peabo5000 is offline
Old 04-30-2006, 10:14 AM
Suspension Yoda
djfrestyl's Avatar
Something is definitely being done wrong.
Funny though how both the problems are with Alpine.
Old 04-30-2006, 10:24 AM
Peabo5000's Avatar
Do you think i have could have plugged the RCA plugs in the wrong white/red connector ? I may try switching, could be a "polarity" issue
Old 04-30-2006, 10:33 AM
Suspension Yoda
djfrestyl's Avatar
Your polarity can't be wrong if you're using RCA's
They only plug in one way.
Maybe you mean balance?
That's not your issue.
Old 04-30-2006, 11:39 AM
phong's Avatar
I just helped my friend install the same deck into his Nissan Sentra. Holy crap did it sound good in there. We didn't use the RCA plugs because he doesn't have a factory amp so we used the speaker-level outputs right from the deck. For comparison, his volume set to 15 was as loud as mine was cranked all the way up to 35. Same exact deck. I guess I'm stuck with the Bose for now...
phong is offline
Old 05-12-2006, 09:53 PM
hooh8r's Avatar
Pearl96Max,
Have you ever used the 70-7551 with a Pioneer DEH P4800MP? If so, what were the results in terms of volume level?
Thanks,
Andrew
hooh8r is offline
Old 05-13-2006, 06:44 AM
§è~® f®ÈÄk
nismos14's Avatar
Considering the output voltage from the Pioneer would be greater then that of the Bose, it will sound justfine.
I installed an alpine unit with the 70-7551 a couple weeks ago, ant the sound quality was VERY good. I don't know what you guys did wrong.
nismos14 is offline
Old 05-13-2006, 08:48 AM
Penguin215's Avatar
Well running only off the deck, you won't get a whole lot of volume, but should be WAY better than the limits on the BOSE.
Penguin215 is offline
bigdogsteve
01-31-2018 04:18 PM
sliptap
09-30-2015 05:57 AM
Kyle Lee Cleveland
09-28-2015 09:03 AM
Kyle Lee Cleveland
09-28-2015 07:58 AM
Quick Reply: Aftermarket HU + Metra 70-7551 = CRAP!
