dimming lights
Old Apr 27, 2006 | 09:05 PM
WhiteMaxima9600's Avatar
dimming lights
Have any of you ever experienced dimming headlights with a small system? I've only got a 400x1 amp, running two 10's but seems when the volumes up i noticed my headlights dim when the bass hits a note... It's not bad but they do dim a little also my gauge lights dim slightly.. I know my amp is'nt pulling more than 30amps or so, think it could be my battery or grounds??
Any suggestions?
Old Apr 27, 2006 | 09:08 PM
slickrick's Avatar
put the car into a lake...you are better off. JK, pulling 30 amps should not be a problem but on a 96 max the alti might need replacing. before you get that nice big amp, look into the big 3 and possibly a new battery. and, run 4 gauge wire for the power/ground.
Old Apr 27, 2006 | 09:44 PM
Fast1one's Avatar
Mine did too...definately upgrade your wiring under the hood and too the amp...
Old Apr 27, 2006 | 10:07 PM
Ok, thanks... No no i can't put her in a lake, she's been too good... alti. got 171k plus.
Old Apr 28, 2006 | 05:05 AM
nismos14's Avatar
§è~® f®ÈÄk
Check all the original grounds for rust/corrosion too. Clean off the battery terminals. Ensure all of your electrical connects are in good shape.
DJLAX152
May 4, 2021 11:46 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
