Best Ground spot in trunk?
Old May 7, 2006 | 11:06 PM
t0mmyr's Avatar
what's the best spot to attach a 1/0 ground to in the trunk? possibly in the spare tire well even if i take a look
Old May 7, 2006 | 11:27 PM
SilverGLE's Avatar
I'm watching you, boy...
I'd say anything on the bottom or the sides.... I wouldn't use any bolt hanging down from the rear deck, though. I tried that with my amp and it wouldn't power on. Ended up using the seat belt bolt for the back seat.
Old May 8, 2006 | 12:19 AM
StillenMax80x20's Avatar
i used a threaded bolt from the rear sub after removing paint from inside of the cabin.... was just easier than the seatbelt trick... though they say grounding low is bad...
Old May 8, 2006 | 12:28 AM
ShRapNeR's Avatar
i use the rear sturt mount bolt
Old May 8, 2006 | 12:32 AM
AscendantMax's Avatar
the spare tire well is fine. that's where i grounded my amps to. just make sure you sand off any paint before securing the ground.
Old May 8, 2006 | 06:18 AM
djfrestyl's Avatar
Suspension Yoda
Grounding low is bad? So by that logic..a ground bolt through the roof is best?
Old May 8, 2006 | 06:27 AM
NismoMax80's Avatar
SuPeRmOd
I used the back seat mounting bolt. Just remove the bottom seat cushion. The seat belt bolt wouldn't budge (probably a good thing).
Old May 8, 2006 | 07:50 AM
Batxel's Avatar
blah
rear strut bolt
Old May 8, 2006 | 08:31 AM
DcMaN's Avatar
not to bust your ***** ascendant but that metal is very thin atleast it is in my 4th gen. ANd i was getting a whining noise so i grounded it to the seat belt bolt.
Old May 8, 2006 | 11:55 AM
ah, probably different between the gens. the metal in my spare area is fairly thick, so i grounded it there.
Old May 8, 2006 | 12:16 PM
mendon99's Avatar
tastey wheat
if youre looking into the trunk, pull away the carpet/plastic away thats there to the left on the wall, mine is on a bolt behind there. only bad thing is it makes my ground kind of lengthy... the shortest ground wire is the best.
Old May 8, 2006 | 05:02 PM
nismo0604's Avatar
x2...................
Old May 8, 2006 | 10:37 PM
WhiteMaxima9600's Avatar
If you can get away with a lengthy ground, use one of the holes behind the carpet/plastic, I just got a large bolt, nut, and washer and cranked it down there.. Don't forget to sand all the paint/primer away first also... No prob. with mine so far
Old May 8, 2006 | 10:39 PM
slickrick's Avatar
lengthy ground=bad. lets keep it under 3 feet if possible.
Old May 8, 2006 | 10:43 PM
Well mines about 2 feet or so
Old May 9, 2006 | 09:58 AM
KUBLKMAX's Avatar
I ran my ground under the car to the frame. I went throught the gromet in the spare tire well.
Old May 12, 2006 | 04:58 PM
ElVito1981's Avatar
i'm thinking about putting my amp under the passenger's seat. Where then would I be able to ground it to? I have a 3rd gen, btw.
Old May 14, 2006 | 10:07 AM
djfrestyl's Avatar
Suspension Yoda
seat bolt.
REDinLV
Aug 15, 2024 12:30 AM
homewrecker
Sep 23, 2015 03:41 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
