Tweeter Popping...ARGH!!!!!!!!!
Old May 12, 2006 | 04:16 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
Ok, crap. One of my tweeters is making a horrendous popping noise when played at moderate levels. One tweeter, and one tweeter only. Before I go ripping everything apart, any ideas as to what causes this?
Old May 12, 2006 | 04:32 PM
AscendantMax's Avatar
happened all of a sudden?
Old May 12, 2006 | 04:40 PM
Order:
- Install 3-way setup (passive)
- Use old-skool Alpine HU (no popping...distortion all-around at higher volume levels due to crappy 2V perouts)
- Install Alpine 9833, popping on single tweeter (not whole system)
Old May 12, 2006 | 07:13 PM
MacAlert's Avatar
The installer
Old May 12, 2006 | 09:41 PM
hmm, gains are re-adjusted for the increased pre-out voltage? but then again it doesn't explain why it's only happening to one tweeter...
Old May 13, 2006 | 08:46 AM
nismos14's Avatar
§è~® f®ÈÄk
The tweeter may be on its way out. I know it sound weird but its possible. How long have you had the tweeter installed? If your running active try raising the HPF on the tweeter.
Old May 13, 2006 | 09:19 AM
Not active. Yeah, I am thinking it may be on its way out as well. GAY! I will disconnect the tweet and run everything at a higher volume...
Old May 13, 2006 | 11:17 AM
Pearl96Max's Avatar
I tend to get a bit irritable
The Egay seller didnt give ya a warranty?
Old May 13, 2006 | 01:31 PM
mendon99's Avatar
tastey wheat
hrmm.. same thing happened to me and on a buddy of mine's, in the rear speaks, turned out the channels on the amp was just bad, or just the RCA inputs, or something, either way it was the amp.. hope thats not the case with yours..
tho im sure your amps were better than mine
Old May 13, 2006 | 01:59 PM
No. for me. There was a warranty, BUT the warranty expired. Methinks I will be needing to buy a new one. Does Dyn have a single tweet for sale?
Old May 13, 2006 | 03:29 PM
Pearl96Max's Avatar
Huh? Their own warranty? You havent even had em that long. I coulda just swapped em for ya.
Not sure if ya could buy singles, definately pairs tho...
Old May 13, 2006 | 04:34 PM
Welp, found the problem...sort of. The tweet "crackles" ONLY WHEN THE CAR IS RUNNING.
Old May 13, 2006 | 04:37 PM
MannyNJ2k2max's Avatar
weird.....
Old May 13, 2006 | 09:14 PM
Originally Posted by MannyNJ2k2max
weird.....
I think 'infuriating' is the proper term.
Old May 14, 2006 | 12:58 AM
nismos14's Avatar
§è~® f®ÈÄk
I had a similar problem, it was my headunit that was causing the problem. Try switching rca inputs from different channels and see if that causes the same issue.
Old May 14, 2006 | 01:23 AM
Digital's Avatar
VIP
Speaker is picking up some sort of interference. (Just a thought)
Old May 14, 2006 | 11:45 AM
GAYYYYYY!!!!
Alright, that at least gives me something to try. I am not going to get the chance to do this until Monday, let's see if we can shut that sucker up.
Old May 14, 2006 | 01:05 PM
djfrestyl's Avatar
Suspension Yoda
If it makes you feel any better, my passenger tweeter gets a very low interference sound when my CC is fan is blowing. Sounds almost like a squeaky fan bearing. I suspect it's because I tapped into the door speaker wire, didn't run new wire.
*tomorrow's task=rewire with new wiring*
Old May 14, 2006 | 01:19 PM
Well, teh Don ran the Stinger Expert™ wiring...I can't see that as being suspect.
Old May 14, 2006 | 05:35 PM
nismos14's Avatar
§è~® f®ÈÄk
The problem I had was also only when the car was on, never did it do it when the car was in acc pos only.
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
1MAX2NV
Jun 19, 2001 12:27 PM
hlh0501
Jan 29, 2001 04:17 AM
ericdwong
Jan 26, 2001 05:51 AM
