8 guage wiring shutting new amp off????
hey im running a single id overstock 10 sub and im using an alpine mrd-500 amp. when i put it at a decent level the amp stops working. do i need to use 4 guage wiring? could that cause it to shut off.... im pretty sure i have it wiring to 2 ohms...
1) Could be running the amp at too low of an impedance and going into protect 2) Find a better grounding point 3) Figure out the voltage your amp is seeing at the time it shuts down 4) Larger gauge wire never hurt
Vaseline is less messy.
I have just the 4 gauge and the things are tight!
I've got 0 gauge, speaker wire and a 4 channel RCA running down the same side.
Previously, I had 0 gauge, 3 separate pairs of RCA's, remote turn on, speaker wire and the power/ground/RCA from my backup camera running down the drivers side.
It CAN be done.
It CAN be done.
Originally Posted by Anarchist
I would've liked a picture of that...![BowDown1](https://maxima.org/forums/images/smilies/bowdown1.gif)
Originally Posted by AscendantMax
just keep working at it, everything will clip back in place. i have a 4 gauge, two sets of RCA's, and speaker wire down the driver side.
Originally Posted by MIXXMAX
Woah! This runs a risk of noise entering thru the system. A good rule of thumb is to run the power wires on the same side of the battery, and run the signal wires on the opposite side. Power and signal wires don't get along when they are running in the same path hand in hand.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
i have zero noise problems. ![Wink](https://maxima.org/forums/images/smilies/wink.gif)
This is a common myth.
![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
![chuckle](https://maxima.org/forums/images/smilies/chuckle.gif)
Originally Posted by SgtSchulze
I thought it would be....I just used what I had handy! Now someone tell me how they got a 4 gauge and speaker wire down the same side and still clip the trim pieces back on?!?!?
![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
Originally Posted by Metal Maxima
I'm running 1/0AWG Stinger Expert...the only way I got the rear cover back on was with the help of my trusty dremel. ![GrinNo](https://maxima.org/forums/images/smilies/grin_no.gif)
![Big Grin](https://maxima.org/forums/images/smilies/biggrin.gif)
Stay away from Vaseline... it's a petroleum products and some of the interior stuff will slowly degrade (engine-side stuff is typically built for petroleum resistance).
Use copious amounts of Astro-Glide (please, no gay comments here)... it's water-based, but stays slick long enough to slide it in the hole (OK, you can make some comments on that one).
hayne
10-05-2015 11:53 AM
