JL 10w3 or Infiniti Perfect 10's
Old Jun 20, 2001 | 08:03 PM
JeepRage's Avatar
i need help, who has what?? good or bad with either?? im up in the air with this one.... i like the JL DVC, but i need help, thanks
Hall
Old Jun 20, 2001 | 08:28 PM
JeepRage's Avatar
wiring
Hall
ok, well im pretty much sold on the JLs, now i just want advice on how to run them at 2Ohms together, in parallel i suppose.. the subs come in 2,4 and 6 ohms each, so what do i want to achieve my 2 ohms?? and how to wire them also. thanks again
Old Jun 21, 2001 | 05:39 AM
Dustyroads's Avatar
Ok, first off are we talking a pair or a triple? You wire them in a series / parallel configuration. For a pair, choose the 2ohm DVC's. You wire the voice coils on each sub in series ie. take the negative terminal of on voice coil to the positive on the other. So now you have 1 positive and 1 negative terminal open on each sub. Then you wire those terminals in parellel.
2 - 2ohms in series = 4ohms
2 - 4ohms in parallel = 2ohms
I'll try to kinda draw something here for you:
from amp---(+)sub1 voice coil1(-)----(+)sub1 voice coil2(-)---back to amp
from amp---(+)sub2 voice coil1(-)----(+)sub2 voice coil2(-)---back to amp
For the triple you wire it the same way, but you choose the 4ohm DVC's and you just have one more sub to wire in parallel.
from amp---(+)sub3 voice coil1(-)----(+)sub3 voice coil2(-)---back to amp
2 - 4ohms in series = 8ohms
3 - 8ohms in parallel = 2.67ohms
Good luck!
Old Jun 21, 2001 | 06:05 AM
JeepRage's Avatar
a pair
Good luck!
thanks, im going with a pair, sorry about that. id rather run @ 2 ohms just because i dont need the power of my amp at 1 ohm, and wont it run a little cooler?? thanks
Hall
Old Jun 21, 2001 | 08:46 AM
ny96max's Avatar
JL's go soft and loose quality in less than a year. I say this cause i work for a JL dealer and get the same complaints all the time. As for Infinity they are ok for the money. I reccomend Kicker subs, they can take anything you give them and will out last any other sub out there. Typically when a customer bings back JL's i either sell them Kickers subs(Solo-barics/VR's/L7 Square) or tell them to buy Alpine Type-R subs.
Kicker has their new line of Comp-VR subs. I reccomend these cause they are now availible in dual 2/4 ohm voice coils and have a rubber surround to make stronger and last longer.
Old Jul 7, 2001 | 11:31 AM
skeelo34's Avatar
check this speaker out,,,,,better than jl and perfects....for way less......unless you cant live with the looks
http://www.ampmanaudio.com/details.a...ry=Subs&ID=550
litch
123
Jan 4, 2024 07:01 PM
chisam14
Nov 6, 2018 08:56 PM
D Mason
Jun 21, 2016 04:43 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
