help w/ 98 I30 and Bose
Old Jul 18, 2006 | 06:44 AM
romerocnj's Avatar
In February I put in a Kenwood DPX301 because the buttons on my Bose HU were breaking off and I wanted an RCA input to plug my ipod into. It has worked fine with the Bose speakers since February but last week the speakers stopped working. The deck works fine (the CD continues to play) but there is no sound. The first thing I did was pull the deck to make sure that there were no loose connections or wires that were touching. Then I checked the fuzes inside the car. There was a blown 15 amp fuse at the top of the center column of fuzes in a slot that is labled "Bose" on the fuze diagram. I replaced it and the sound came on for a while. While the sound was working I was adjusting my balance and fader to see if all the speakers were functioning. The Right Rear speaker was not working and was just putting out a low constant popping noise. The next day when I started the car the sound worked for like 2 seconds and the fuze popped again. No matter what I do, as soon as I power on the HU the fuze pops. I've tried disconnecting the Right Rear speaker to see if that is what was causing the short and that doesnt work. What should I do next? Any help would be greatly appreciated.
Old Jul 18, 2006 | 12:55 PM
nismos14's Avatar
§è~® f®ÈÄk
Replace the speakers problem solved. Sounds like issues with the bose amps/speakers. Maybe one is shorting out.
Old Jul 19, 2006 | 09:17 AM
romerocnj's Avatar
anybody else got any ideas?
Old Jul 19, 2006 | 09:19 AM
nismos14's Avatar
§è~® f®ÈÄk
Did u check them for shorts? How is the HU connected to the bose amps? That first post is so jumbled.
Old Jul 19, 2006 | 10:00 AM
djfrestyl's Avatar
Suspension Yoda
Have a meter or test light? Start checking wires at the HU, amp, speakers.
Popping fuses usually = short. Now it's just a matter of finding it.
Old Jul 19, 2006 | 11:36 AM
romerocnj's Avatar
thanks to everyone who replied. after messing around with it myself for a while i decided to take it in to a local car audio shop and let them find the short.
Old Jul 19, 2006 | 12:24 PM
Hexon's Avatar
They will propably charge you a lot. Just replace the bose speakers with some aftermarket ones and you will like the sound better since you currently have no sound.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
uttadms31
Sep 30, 2015 05:24 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
