Whats your opinion
Whats your opinion
Ok so my friend at work sold me a 18" Kicker comp cvr its 2 years old and he needed money badly and everything from his car was stolen but that. Now my question is what will I need to buy to get this beast up? I have a brand new in box 1000w(so it says) 2 channel sony amp and a 1 kw cap. What all will still have to be bought to get this thumpin? besides box ofcoarse. I just want it to hit not talking about major comp here maby lowest i can go with this sub. Sorry i am terribly new in the audio department and i need your experts to help me out here.
Or should i just sell it and but something else
Thanks for any help. and please no flaming
first you are going to need a amp wiring kit. then the sub box (which you say you have already) an amp (which you say you have already) and then are you going to have the system wired to the stock headunit or are you going to buy an after market headunit?
If you buy an after market headunit you'll need the dash kit wiring harness antenna adapter and the headunit
Originally Posted by filtor1
You won't be able to get the required air space for that thing in your trunk. Def sell it, or use it as a HT sub if you don't have one.
Originally Posted by Fast1one
You are not very creative my friend...currently my 15 is sitting in 4.2 cubes after all displacements...over 6 cubes without and I can still take my box out
Also an 18 inch comp is gonna require quite a bit of air space, I'm assuming in the 7 - 8 cube range. Even the 10's 12's and 15's required alot of air space for the Kicker Comps.
yea i figured that so tomaro me and my dad are going to attempt to build a box to fit. Anyone know of any other max with an 18? Also any ideas for box? which direction fire? any input is welcomed and helpful thanks
That 18 will work well in about 8-8.5cf. Could you find the air space, absolutely, but you will choke the sub out with the lack of airspace needed around the box restricting the output into the cabin. If you make the box much smaller, you are just limiting the drivers output, in effect chocking it out internally instead of the previous external. A 15" requires a MUCH smaller box.
Def don't lack creativity. My 12"s are in 4.5cf and the box barely fits. I had to actually bend metal to get it in and out. 5th gen suck for that.
anyone have a blueprint for a box for a 18" thats what I really am needing. I'm not into comp or anything and wont have it up extremely loud. just a guy that loves to hear and feel his music
edit... I have no experience in making a box this will be my first one. I am very handy and have all the necessary equipment just need a guide thanks
Originally Posted by nismos14
Pics?
Why go through all the trouble if you just want to hear and feel your music? Just get a better quality 12, and you won't lose all of your trunk space. You will most definately feel it.
Just run it sealed in around 6 cubes...you dont need to run it ported...Currently my box dimmentions are 36 wide, 26 deep, and 13 high, that should put you right around 6 cubes (little less) after woofer displacement....I can go bigger, but that was the easiest without making a wierd shape...
REDinLV
Aug 15, 2024 12:30 AM
dvcamp
Sep 18, 2015 10:17 AM
