Help installing mono amp PLEASE!!!
Old Oct 3, 2006 | 07:44 AM
ShIft_uR FacE's Avatar
Ok, so i ran a 0 gauge to a distributor in the trunk, 4 gauge to my high/low and also to my mono. Now, i hook up everything right... I have 2 problems. One, my components on my passenger side wont power up. Second, amps turn on but no signal to subs. Checked wiring and it all seems to be fine. The "remote" wire i connected to my mono amp and then to the 4 channel. Is that a no-no? Im not sure what wire from the headunit its supposed to be attached to. I have an alpine 9855. Any help would be great. Thank you.
Old Oct 3, 2006 | 08:44 AM
nismos14's Avatar
§è~® f®ÈÄk
This could be an issue with the components, a loose wire, blown speakers, bad amp, bad input, bad signal. You're running rca's from the headunit to both inputs on the amp right?
Double check the wiring inside the box, and on the terminals of the box and amp.
This SHOULD be fine, and since both amps are powering up its not an issue.
Um... the headunit should attach to the wiring harness. The RCA's from the headunit should connect to each amp. The blue/white wire from the headunit should go to the remote wire connection on each amp.
Thank you.
You're welcome
Old Oct 3, 2006 | 08:54 AM
burnurass's Avatar
he never said he hooked up RCAs....maybe that's the problem. Getting no signal.
Old Oct 3, 2006 | 08:57 AM
nismos14's Avatar
§è~® f®ÈÄk
True, but one side is getting sound hmm..
Old Oct 3, 2006 | 11:58 AM
BLK2BLU's Avatar
Maybe not all are hooked up....
Old Oct 5, 2006 | 08:07 AM
problem fixed...buddy wired my subs wrong so i rewired them. Put dynamat on the trunk lid but now i have tremendous rattle from my rear deck. More dynamat?? Also, lights dim mostly in the rear tails, hardly any from headlights or fogs. Almost done with the big 3 but would adding an optima help?
Old Oct 5, 2006 | 11:42 AM
BLK2BLU's Avatar
Its hard to make the H.I.D.'s dim cuz they are not like regular lights. The optima would help but a BatCap is the ultimate way to go.
Old Oct 6, 2006 | 12:17 PM
I see so many ppl saying a cap isnt worth it...but im sure it has to help even if it is a little. Just dont enjoy people behind me getting blown up from my taillights.
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
popdedop
Sep 11, 2015 11:17 AM
