stereo installation?
Old Oct 14, 2006 | 10:24 PM
travmaximas1998's Avatar
hey guys,
i need some help on how to install new speakers in the front and the rear, and a new stereo!
anybody with suggestions and pictures of their own installation will be appreciated! thanks!
(i have a 98 maxima se, without the bose system)
Old Oct 14, 2006 | 10:30 PM
Cdg2125's Avatar
you need to post this in the audio forum. Not in this forum. You'll get more responses that way.
Old Oct 15, 2006 | 10:23 PM
RyanTaylorClark's Avatar
Yeah, take it to the pros .... j/k (I am a pro, so I am saying that). Radio is a little work to get out, but pretty straight forward. Take off trim around shifter, unscrew ashtray, pull outward on ashtray, unscrew two screws on bottom of radio area. Take off vents/clock area at top, unscrew two screws on top of A/C area. Whole piece comes out at once, then do the rest on the bench. Doors are also pretty easy. Screw in bottom of area you grab to close the door behind clip in cover, 2 screws (I believe) on bottom of door, CAREFULLY unclip bezel around handle, pull outwards on panel (2 clip-in pins on each side), then lift up to get off lip by window. The backs are also a little of a pain to get out, but also pretty straightforward. Lift out bottom of rear seat (lift up on front), unscrew 2 10mm on each side at bottom and 2 inside fold down trunk access behind fabric cover (lift up on area between trunk and the armrest), lift seat back up and take out, snap off sides between rear deck and headliner, take off rear brake light (if you have it) lift up on rear deck. This is pretty much how my 96 comes apart, but you may seriously want to consider spending the few bucks it will cost to let someone else do it so if they break it they fix it for you. There are a few parts that are kinda easy to mess up (the vent area, the bezel around the handles, the side pieces in the rear) and I know I have a few broken pieces from my dad messing around with my car before I bought it from him. I wish he would have just paid to have someone else do it. Hope this helps!
MaxLife17
Jun 27, 2019 01:37 PM
2kmaximel
Sep 16, 2015 03:19 PM
EdRomo86
Sep 12, 2015 07:49 PM
Violator
Sep 9, 2015 10:14 AM
Johnny9595
Sep 3, 2015 05:18 AM
