Hey guys I need your help on another car.
Old Nov 19, 2006 | 11:29 AM
Deckdout2's Avatar
Play with my balls
Does anyone have a wiring diagram for the 2006 Nissan Altima 2.5? I've been searching online and I can't find the schematics for that year anywhere. It seems that the diagram for the 2004-2005 are the same, but no 06. I also need to know if the 561t Remote start module will work on this car as well. I have a Bulldog Security with alarm and remote start, but I would rather simplify it by using the 561t as I have on my Maxima. Any help or some sort of direction is appreciated.
Thanks,
-Paramy
Old Nov 19, 2006 | 11:43 AM
kpr10is's Avatar
12volts | green(40A) | + | ignition harness
Starter | black/red | + | ignition harness
Second Starter | black/yellow | + | ignition harness
Ignition | black/red | + | ignition harness
Accessory | red | + | ignition harness
Second Accessory | white/blue | + | ignition harness
Key Sense | black/red | + | ignition harness or BCM, pin 37
Power Lock | brown | - | BCM to right of fuse box, pin 45
NOTE: These wires are only available on vehicles with left front only power window anti-pinch system. On vehicles with left AND right front power window anti-pinch system, use the factory alarm arm and disarm wires for door locks.
Power Unlock | pink | - | BCM to right of fuse box, pin 46
Lock Motor | yellow/red | 5wi | BCM to right of fuse box, pin 65
Unlock Motor | green/white | 5wi | BCM to right of fuse box, pin 59
Parking Lights+ | red/blue | + | driver kick, harness to rear
Hazards | green/red | - | BCM to right of fuse box, pin 29
Turn Signal(L) | green/black | + | BCM to right of fuse box, pin 60
Turn Signal(R) | green/yellow | + | BCM to right of fuse box, pin 61
Reverse Light | green/white | + | driver kick, harness to rear
Door Trigger | see notes | - | BCM to right of fuse box
NOTE:The LF door is lt. blue in pin 47, RF door is pink/blue in pin 12, LR door is red/black in pin 48, and RR door is red/white in pin 13. Use all four wires and diode isolate each.
Dome Supervision | red | - | BCM to right of fuse box, pin 63
Trunk/Hatch Pin | purple/white | - | BCM to right of fuse box, pin 42
Hood Pin | N/A
Trunk/Hatch Release | red/black or blue/red | - | BCM to right of fuse box, pin 30
Factory Alarm Arm | pink/blue | - | driver door module in door, pin 4
NOTE: Meter this wire while turning the key in the driver door key cylinder.
This wire will also lock the doors.
On vehicles with left front only power window anti-pinch system, this wire is found at the BCM to the right of the fuse box, pin 8.
Factory Alarm Disarm | white/blue | - | driver door module in door, pin 5
Single pulse on this wire will disarm the factory alarm, and double pulse will unlock the doors.
On vehicles with left front only power window anti-pinch system, this wire is found at the BCM to the right of the fuse box, pin 7.
Tachometer | NOT red, pink, or black | ac | any ignition coil or fuel injector
Brake Wire | red/green | + | brake pedal switch
Parking Brake | green | - | parking brake switch
Horn Trigger | green/white | - | horn switch
As far as I can tell from Directechs, the 05 and 06 are the same, but there are a few changes from the 03-04 wiring diagram.
You will of course need a 556U bypass module, as you do in the maximas, no matter what remote start you go with. Id assume you already have one in there for the Bulldog you already have.
Old Nov 19, 2006 | 12:00 PM
Deckdout2's Avatar
Play with my balls
Hood Pin | N/A
You are the man! Thank you very much for your help. The bulldog is actually not installed and was bought as a gift. I was trying to decipher if I should just sell this and install the 561t like in my Maxima (if it works), so I can keep the factory keyfob still. Let me know your opinion on this setup, and thanks again for the assist!
Old Nov 19, 2006 | 01:20 PM
kpr10is's Avatar
If it was me, Id trash/give away/sell the Bulldog and get a DEI simply because its Bulldog vs. DEI, and all the reliability that goes along with that comparison
Old Nov 19, 2006 | 09:09 PM
Deckdout2's Avatar
Play with my balls
I've always had trust in all my DEI products and put in that perspective.....it makes sense. That's what I'll do, thanks!
Hondarydr
Dec 30, 2024 06:15 PM
LilVito
Oct 25, 2019 08:12 AM
vybz05
Dec 10, 2015 07:38 PM
spidgeon
Aug 24, 2015 11:14 AM
Nintensity
Aug 13, 2015 05:41 PM
