Replacing 96 Non-Bose Rear Speakers
if i buy aftermarket speakers to replace the rear deck speakers
what kind of wiring is involved? (if any)
if i buy the speakers off ebay i assume no extra wiring accessories will be included.
any kind of details are appreciated. thanks
Its too easy...I'll tell you IIRC real quick.
Rear Seats...
1. Pull out bottom section of rear seats by pulling down on the plastic locking tabs on the front bottom of rear seats. It should pop right off, then lift them out....
2. Remove both bolts on the outer bottoms. IIRC they're 12 mm.
3. Pull armrest down and remove plastic piece on bottom. There are two bolts under there i thnk.
4. Lift up on the rear seat backing and move seat belts out of the way and it should pop out...ten pull it out.
5. apply even pressure to the rear deck lid and it will pop out, its only plastic tabs holding it on.
That should be it
jskirwin
06-08-2016 08:49 AM
vingodine
45
05-21-2016 12:46 PM
Huttig2009
09-25-2015 03:31 PM
