Started the SpecV install...
Old Feb 7, 2007 | 11:04 AM
  #81
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by mendon99
interesting. do you have the links to where sounddomain talks about it? i'd like to read them..
not trying to be an ***, seriously interested in seeing what it says..
I went in the forums sections of both caraudio.com and sounddomain.com and searched for "big 3" and "upgrade wiring" and found a bunch of threads.
Main ca thread: http://www.caraudio.com/forum/showthread.php?t=152355
Main SD thread: http://forum.sounddomain.com/forum/u...c;f=5;t=007801
Old Feb 7, 2007 | 11:07 AM
  #82
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by BLK2BLU
Is there any place the fuse should be? i.e. can it be closer to the battery?
It can be closer to the battery. It just happened to fit well in that location in my Sentra.
Old Feb 25, 2007 | 05:28 PM
  #83
phenryiv1's Avatar
Mod her. Ate her.
FINALLY...Components installed! It took 10 hours, total (I did more than just install the components).
Vehicle:
View of door Screws:
Underside of handle showing location of clips:
Brokeback door handle:
Stock Door:
Old Feb 25, 2007 | 05:35 PM
  #84
phenryiv1's Avatar
Mod her. Ate her.
Tweeter Mounting details:
Stock Tweeter:
Hertz Tweeter Mount on stock bracket:
Hertz Tweeter installed on stock bracket:
Hertz Tweeter mounted in stock location:
...and with stock A-pillar cover in place (not much to see here):
Old Feb 25, 2007 | 05:42 PM
  #85
phenryiv1's Avatar
Mod her. Ate her.
Midrange details:
Snaking the wires to the door (note the use of a HUGE zip-tie as a wire snake):
Spacer installed; part of deadening completed:
Mid in Spacer (Driver's side):
Mid in Spacer (Passenger's side):
Door Deadened with both mass and barrier loading:
  #86
nismos14's Avatar
§è~® f®ÈÄk
Ooo lookin good so far!
Old Feb 25, 2007 | 05:44 PM
  #87
phenryiv1's Avatar
Mod her. Ate her.
One more pic...
Proper wire routing:
Old Feb 25, 2007 | 05:45 PM
  #88
nismos14's Avatar
§è~® f®ÈÄk
How do they sound?
Old Feb 25, 2007 | 05:59 PM
  #89
phenryiv1's Avatar
Mod her. Ate her.
Originally Posted by nismos14
How do they sound?
Good. I am still oversized on the box fo rmy sub and most likely everything is underpowered. I remember when an RF amp w/ 50 watts per channel would break windows...this Xtant is very clean, but the 50 watts per channel is really not as far-reaching as I had hoped. The Hertz have very smooth highs and very clean midrange. Midbass is there if i lower the HPF to 50 Hz, but they sound very clean at 80 hZ (I am using the built-in x-over on the Pioneer). I could not push the Hertz to distortion without maxing out the volume on the HU, and that is with the amp's gains up around 90%. Like I said, the amp is clean, but just does not have a lot of headroom.
I think that with a few more watts, these would SCREAM. I DON'T like the in-line crossovers, but they would be easy to upgrade, and they were a snap to install because they can be tucked just about anywhere. Also, the mids have a basket that seems a bit thin. I could probably torque the mounting screws enough to actually bend the basket/flange if I tightened them any more. You could see the mounting flange start to bend as the screws cinched down.
On the plus side, the speakers are VERY musical, and don't sound like speakers- they make music sound like music. For the price, they are the best components I have ever heard or run. My only wish is that I had more power to put to them, and that I had a more well-tuned sub to augment them.
Old Feb 25, 2007 | 06:16 PM
  #90
nismos14's Avatar
§è~® f®ÈÄk
Nice! So more power and a smaller box and you'll be golden
Old Feb 25, 2007 | 06:34 PM
  #91
djfrestyl's Avatar
Suspension Yoda
VERY nicely done. Glad it worked out. Nice job
Old Feb 26, 2007 | 05:39 AM
  #92
phenryiv1's Avatar
Mod her. Ate her.
Smaller box to start. I will be putting blocks of wood in the current box until it sounds the best, then I will build a new box with that same volume.
After driving it for an hour today, I realized that it gets more than loud enough for daily driving, so while my old basshead, hear-me-down-the-block self would need more power, I will take this nice, clean sound and put the $$$ from another amp into something else...
Old Feb 26, 2007 | 05:40 AM
  #93
phenryiv1's Avatar
Mod her. Ate her.
Thank you!
Old Feb 26, 2007 | 06:24 AM
  #94
machinehead131's Avatar
very nice install
Old Feb 26, 2007 | 07:31 AM
  #95
nismos14's Avatar
§è~® f®ÈÄk
Sounds good man, glad its actually louder than you initially thought
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
