Basic amp wiring problem
Old Jan 3, 2007 | 07:22 PM
J_Ketzer's Avatar
If this was in stickies then I just couldn't find it --
I'm trying to connect an amp and sub to the stock 97 Bose HU via the PAC AOEM-NIS2 adapter box, using the amp turn-on lead supplied with the PAC adapter. The amp turns on, but only when I'm using the radio; tape and CD modes turn the amp back off.
Is that turn-on lead actually connected to the motorized antenna or some such? Also how do I fix it? I see a wiring diagram that indicates that a solid red wire leading into the rear speakers is a +12V line... is it possible to tap that for an easy amp turn-on?
Thanks a lot.
Old Jan 3, 2007 | 08:03 PM
nismos14's Avatar
§è~® f®ÈÄk
There is another blue wire that needs to be attached to that radio signal, or another wire that is similar, I never used the pac so I'm not sure that there is another wire back there.
Old Jan 3, 2007 | 08:42 PM
Domf3's Avatar
You need to splice into the wiring harness for the remote wire, the hanging wire is only hot when the radio is on cause it's f/ the power antena.
Old Jan 3, 2007 | 09:27 PM
J_Ketzer's Avatar
EDIT: I found and tapped the correct wire and now it works. Thanks again for your prompt replies.
The Frye
Sep 2, 2021 11:03 AM
