Installing the 530T on the 791XV viper?
Originally Posted by mendon99
there should be directions in there, no?
I also want to know how to program the pager ahead of time.
The only things that will wire to the actual alarm brain outputs will be an aux channel (usually channel 4 or 5) for roll down, and ground when armed (orange) for roll up. Other than that, its just power, ground, and the 4 wires running into each door.
Other than that, read this a few times and follow it. If youve got pretty good electrical knowledge, you should be ok.
http://directechs.com/techtips/pdfs/...htips/1042.pdf
P.S. To newbs reading this, PLEASE do not attempt this on your own. The only reason I said what I did above is because MaximaPolak is a regular on the .org.
If it is anything like my 99 was, good luck to you, PITA! You have to go into each door for it. So if you only got 1 530(2 windows, 2 ways) you have to go into both doors. But maybe the new ones aren't that bad. Good luck.
Originally Posted by MaximaPolak
Bump...anyone know how much Don would charge?
He would prolly charge you minimal and tell you to return the 530T because its not needed.
I had don do my alarm and the 530t wasn't needed. I have window roll down AND up and also trunk release FTW.
PM don or give him a call..it's worth a trip to visit him.
Wiring the 529T or 530T is not complicated at all if you are knowledgeable about electrical car wiring. Like someone said before, the module is considered as an aux output. The original alarm must have an aux input for it to function. All you have to do is tap into the wires to the power window wires (up AND down direction to both doors) for the 530T, or (up OR down direction to both doors) for the 529T. I had installed a 530T in my Viper alarm in my '95 Max when I had had it. Nice feature if you want to remote control your power windows.
Why isn't the 530T needed?
MaxLife17
Jun 27, 2019 01:37 PM
