RCA Cable Q
Old Mar 31, 2007 | 08:45 PM
Domf3's Avatar
RCA Cable Q
I need to run a set of RCA's to my trunk. I've got a 5th gen. What length cable should I get? I want the cable to reach from the back of the headunit to the back of the trunk. Does 20' sound right or should I get a shorter length?
Old Mar 31, 2007 | 09:46 PM
kpr10is's Avatar
17 feet is the standard length and will be fine.
Old Apr 1, 2007 | 10:31 AM
mattj10's Avatar
http://www.knukonceptz.com/productDe...prodID=KRY2-6M
i have this one in the 4 ch variety and it gets the job done. a little long, but anything under 5 meters will be cutting it short
Old Apr 1, 2007 | 11:07 AM
2AZN2DMAX's Avatar
You want the shortest RCA as possible to do your install, so there won't be loss of signal. Less length, less loss of audio signal. If you run it through the center all you need is 13.5 feet. If you are running it on the side get 15.
Old Apr 1, 2007 | 01:20 PM
1996blackmax's Avatar
I have went the long route. I was originally going to have my amps in the trunk, now they are under my seats. Just used the same long cables, and some zip ties to get them under control behind the dash .
I would go with the 17 feet.
Old Apr 1, 2007 | 01:24 PM
AscendantMax's Avatar
17 feet in my 6th gen. there's still a decent amount of slack leftover.
Old Apr 1, 2007 | 03:28 PM
mendon99's Avatar
tastey wheat
exactly what Im doing. id rather have shorter ones, but whatever..
gigabyte
Jan 6, 2017 06:05 PM
knight_yyz
Oct 24, 2015 08:05 AM
sliptap
Sep 30, 2015 05:57 AM
pktaske
Sep 4, 2015 08:40 AM
