Got a surprise from the UPS man yesterday
Old Apr 12, 2007 | 06:47 AM
  #41
burnurass's Avatar
Originally Posted by nismos14
All you fegs talking about wood
dont' be jealous...i'll let you touch don's wood before we wrap it
Old Apr 12, 2007 | 01:38 PM
  #42
Greeneyes's Avatar
So umm how do you like the bluetooth on it? I think I'm about to purchase the unit... But why do you say you wouldnt get the bluetooth if you have the headunit hookep up to amps?
Also did you bypass the security features for the DVD player and Navi functions? difficult to do?
Old Apr 12, 2007 | 02:03 PM
  #43
burnurass's Avatar
The bluetooth is GREAT on the unit. And you are exactly right...the bluetooth UNIT needs to use the headunit high level outputs for sound. It's the only way it will work. It WILL NOT send the signal through the low level preouts for sound.
Eclipse's answer:
Hello,
The Parrot adapter has a little amp that cannot be in line with a powerful amp because the input voltage would be to high and blow out the inputs on the little amp. Run the back speakers like normal, through the parrot adapter using the mute wire.
DVD & navi function lock out is easy to disable...just ground the parking brake wire.
Old Apr 12, 2007 | 10:45 PM
  #44
Greeneyes's Avatar
Theres no way of having it flush to the dash? Do you also have an iPod connection? if so where do you keep it?
Old Apr 13, 2007 | 04:54 PM
  #45
burnurass's Avatar
what's an iPOD?
YOU can if you want to drill new holes in your brackets. I chose not to as I'm satisfied with the way it is.
tarun900
19
Dec 20, 2021 06:57 PM
ef9
Oct 4, 2015 08:43 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
Sep 27, 2015 08:37 AM
