Tweeters
Old Jul 11, 2001 | 04:40 PM
hockeyghst's Avatar
how wuld i got by hooking up my tweeters in my car??? i already tried hooking it up + - on the front speakers but nothing happens what am i doing wrong........by the way i am goint + to + and - to - 95 max
Old Jul 11, 2001 | 05:01 PM
jashick's Avatar
What kinda system do you have? Did you hook up the tweeter by itself or a component system? If the latter, did you check to make sure the capacitors in the crossover aren't disconnected? Did you check the fader and/or balance settings? Does the old speaker work in the same hookup?
Old Jul 14, 2001 | 10:30 AM
ny96max's Avatar
please explain further im a lil confused
Old Jul 16, 2001 | 09:10 AM
jashick's Avatar
Sounds like he's trying hook up tweeters by wiring in parallel to his front speakers...He should get sound but doesn't.
hockeyghst: Though you should get some sound out of the tweets, I'd advise against this type of setup without a crossover or inline bass blocker.
You're changing the overall impedance of that speaker channel. This can have a minor or significant impact depending on your setup...
Old Aug 27, 2001 | 01:41 PM
jiaxima96's Avatar
I'm thinking of adding tweeters to my 96 GXE (non-Bose). I'd like to know what I should look for if it's an aftermarket one, such as Ohms (4 Ohms?), type of magnet, frequency response, power handling, etc.
Thanks in advance
Old Aug 27, 2001 | 06:05 PM
TurDz's Avatar
If you decide to go with tweeters, you need a dedicated amp to power them, that is, if you care about good bass response and quality sound.
I don't think I would ever consider components without an amp...I've really discovered that it makes a world of a difference.
95naSTA
Sep 21, 2015 06:50 PM
MikesChevelle
Aug 9, 2015 11:50 AM
1MAX2NV
Jun 19, 2001 12:27 PM
hlh0501
Jan 29, 2001 04:17 AM
ericdwong
Jan 26, 2001 05:51 AM
