Smoked an amp WTF?
Old May 13, 2007 | 03:40 PM
Domf3's Avatar
Smoked an amp WTF?
So I just finished pulling out the amp I was going to use for my highs because I blew it up. Here's my story...
I've got an 01 max and planned on pulling out the bose. I started off by adding a PAC w/ RCA's to the stock blose headunit, wired a set of RCA's, ran power wire/etc. added an amp and sub. It worked, but I decided I wanted some components.
I ran another set of RCA's, pulled out the bose amp for the stock speakers, and used the speaker wires from the bose harness. I checked the wires, they were definetly the correct output wires.
Here's where I think I screwed up. I wanted to see if everything worked, with the stock bose speakers still in. I turned the radio on and the speakers played, sounded distorted, then I look back and see a small puff of smoke come from the amp. Would using the stock speakers kill the amp? It's a JL 300/2 and its supposed to be stable at 2 ohms stereo. The fuse never blew on my power cable. Also, why didn't the amp shut down, wtf?
I'm ready to cry. I spent about 20hrs wiring everything, my hands are bloody from running wires, and I've got nothing to show for it. HELP!
Old May 13, 2007 | 04:24 PM
slickrick's Avatar
you sound like a man who needs to drive to Don's.
Old May 13, 2007 | 04:56 PM
mendon99's Avatar
tastey wheat
somethings hooked wrong...
shorted speaker somewheres?
Old May 13, 2007 | 05:03 PM
Domf3's Avatar
lol, I am going to see the Don. No doubt. But I was hoping to have the amps hooked up. I know Power/grounds/RCA's are good. I'm just wondering if the stock bose speakers would blow an amp?
Old May 13, 2007 | 05:21 PM
Torgus's Avatar
sounds like it was the amps time to go. even if the speakers gave a really low impedance like a .5ohm load the amp would just shutoff afaik...maybe those were not the right wires...how did you check them? good luck! either way it sounds like you need a new amp. or have it repaired...
Old May 13, 2007 | 06:33 PM
nismos14's Avatar
§è~® f®ÈÄk
Did you hook up all the bose speakers to the amp?
Sounds like the amp REALLY didn't like the 1 ohm load from the bose speakers... AND it's protection either 1) failed, or 2) failed because of improper wiring.
Old May 13, 2007 | 07:22 PM
mendon99's Avatar
tastey wheat
more than likely would have just shut off is the impedance was too low.. something else was wrong.
Old May 13, 2007 | 07:23 PM
Torgus's Avatar
thats what i said too.
Old May 13, 2007 | 07:53 PM
slickrick's Avatar
You're gonna catch some flack for using JL from Don haha.
Old May 13, 2007 | 07:58 PM
Pearl96Max's Avatar
I tend to get a bit irritable
Maybe cause its a JL?
Sorry...couldnt resist.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
ballerchris510
Sep 10, 2015 09:35 PM
