installing bigger subs to oem bose amp?
Trying to change the rear subs on my 04 max prem package with some bigger subs. anyone knows which wires i gotta tap on the rear sub amp? I'm lost as to which ones i gotta hook up. Any help is appreciated. I'm not gonna install a amp now though, i'll do that later.
How about adding my amp to the setup? I would need a hi-lo adapter even if its just for the subs? I see there's another connector that goes to the factory sub amp. It's 2 blacks, yellow, white. Are those the remote turn on, 12+, and negative?
If you have a voltmeter test to see the voltages on each line, then tap into the ones that send the signal. It would probably just be easiest to leave the BOSE speakers and amps connected, and just take the signal right off the wires going to the speakers.
6spd4dsc
05-09-2022 12:30 PM
Max139617
08-29-2015 02:55 PM
Car Addict
Audio/Video/Electronics
08-27-2015 09:01 AM
