Need Help With Amp
Old Oct 21, 2000 | 12:13 PM
MidnightSpeed53
Okay I have a problem with my amp it is acting kinda funny
i had it for about 6 months now and i think its a kinda generic amp so i dont know its a Urban Work Series amp
but for the past couple weeks my amp has been just turning off i dont know whats the reason for this
maybe its because i have a pyramid EQ but my amp is at half gain and the its a 800 4 channel amp im powering a 10" JL w0
and i really wanted to fix this
please help
Old Oct 21, 2000 | 12:54 PM
MidnightSpeed53
My Answers
Originally posted by doug
Things to note..
a) is the amp cutting off and the power to the amp going?
look at the amp power light to see if it goes out.. or if it goes into protection.
Goes onto protection
(i) you may have your speaker wires touching, thus causing the amp to go in protect mode.
Made sure wires not touching still turning off
(ii) your amp may not be grounded properly, ensure that your grounding to the body of the car and not something just laying around
grounded to the trunk body so its right on the trunk floor
(iii) you may have a power lead, remote turn on lead that may not be connected properly thus shorting out the amp.
made sure amp is correctly connected to remote not a problem
b) is the amp volume cutting off yet power is still going to the amp?
(i) your speaker output wiring is in correct
Speakers are correct bridged
(ii) you maybe running in 2 ohm mode which the speakers nor the amp is able to do.
Have no idea how to check this
(iii) your amp maybe running real hot due to temp and shutting down.
Not hot but still turns off
(iv) check your RCA connectors, make sure they are connected correctly...
Changed the RCA's still turns off
For troubleshooting amp probs, I always use two things... a alternative speaker(not in the car) with wire connected... an alternative source to connect to the amp.. I use a portable cd player.
connect the amp to the portable cd player and the alternative speaker to the amp's output.. then troubleshoot backwards.. just a thought... good luck
Still turns off i cannot figure it out
Old Oct 21, 2000 | 01:11 PM
MidnightSpeed53
okay i think its just the speaker because it doesnt go off when i take the speaker off
but im just wondering why though cause the JL is supposed to be 4 ohm
so why would this thing be dropping so much??
Old Oct 21, 2000 | 04:39 PM
Micah95GLE's Avatar
doug, subs aren't "stable"; amps have the job of being "stable" under load. W6s have dual 6-ohm voice coils, so each W6 is capable of either a 3-ohm load or a 12-ohm load.
Old Oct 23, 2000 | 10:05 AM
breaux124's Avatar
Every point that Doug mentioned are great points.
Also, sometime amps have thermal protection. If the amp is playing too hard and is getting too hot (usually from overdriving) it will shut down. Does your amp have enough space around it for the heat to dissipate? Don't mount the amp directly to a thick carpet. Also, double check for shorts in your speaker wire, this could be the problem, this could be inside to box, maybe on the connectors.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
