Question about my amp!!
Old Jul 29, 2001 | 09:56 AM
hockeyghst's Avatar
i have two 15 inch subs and an 800 watt amp......what guage wire should i use??? what guage wire would i need to use if i had a 1400 watt amp???? thank you guys....would i have to change the fuse on the amp also???? if so what fuse should i change it to.........?????????
Old Jul 29, 2001 | 05:49 PM
MaximaMan's Avatar
specifcs?!?
Its kinda hard to tell what you are looking for exactly but lemme try and help you out
200-400 watt amps at minimal can run an 8g. wire!!
1000watt + i'd go with 2 or 4g.
And let me remind you your ground needs to be of the same size else your currents just won't work..
ie. if u have a 4g wire from the battery to your amp, and your ground is 8g. your only going to get the flow of an 8g wire...found out the hard way!!
and yea i'd change the fuse to an 80 or so. My friend runs
2 12's @ 800watts and he has the 80 fuse...runs great =D
Hope this helped
Old Jul 29, 2001 | 08:20 PM
khrfadz's Avatar
a 4 gauge wire and an 80 watt fuse ull be fine...thats the same setup i have for my l7's
Old Jul 29, 2001 | 09:16 PM
hockeyghst's Avatar
thanx for ur help! i appreciate it
chisam14
Nov 6, 2018 08:56 PM
Unclejunebug
Apr 2, 2016 05:42 AM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Socalstillen
Sep 26, 2015 12:01 PM
