how do u know ur amp is dead ??
Old Aug 1, 2001 | 01:39 PM
tunedup's Avatar
I just bought a 12 jl wo sub and my amp is not even turnin on
i triplechecked the wires and the fuses
i didnt change the fuse but i know its not gone.
the amp will not turn on is it gone?
is it repairabble
the amp is 3 months old
it is a 500 poweracoustik 2 ch amp
i was powering a 400 w pioneer single 12 with it
Old Aug 1, 2001 | 02:19 PM
jashick's Avatar
is it repairabble
You checked with a multimeter that you're getting
12V on power wire, 12V on remote-on wire?
Did you check to make sure the amp doesn't have another
onboard fuse?
Old Aug 1, 2001 | 04:32 PM
tomasm's Avatar
try these things
if you want to see if your amp works period get your power wire and connect it to the remote of the amp that way its on direct. dont do this for a long time just to see if it comes on if it doesnt the amp is saying good bye to you. tell me what happens.
Old Aug 1, 2001 | 07:25 PM
khrfadz's Avatar
turn on ur music and listen to the amp. usually ull be able to hear a slight humm. if that aint the case check the fuse it might be too weak.
Old Aug 1, 2001 | 09:30 PM
99niner99's Avatar
first go through with a multimeter to make sure your input terminals have adequate power (12V)...then check the output terminals (speaker terminals/channels) to see if you're getting a reading....if not, then take apart the amp to check to see if there are any internal fuses (although i don't think that power acoustik amps do). If still no luck then start looking for a new amp.
chisam14
Nov 6, 2018 08:56 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
popdedop
Sep 11, 2015 11:17 AM
markevans999
Sep 10, 2015 04:29 PM
