Adding Sub to Bose
Old Aug 11, 2001 | 09:34 PM
DaMaxima's Avatar
Yeah I know I need a line converter but exactly where do I tap into the wires at and does this mean I dont need any RCA cables?
Old Aug 11, 2001 | 09:53 PM
JeepRage's Avatar
if your amp has a high level input, all you need to do is tap in from the rear speakers. easy enough, but make sure you tap in from AFTER the bose speaker amp. (take the plastic covers off the speakers to get access) goodluck
Old Aug 11, 2001 | 10:01 PM
DaMaxima's Avatar
Do I only have to tap into the wires on both rear speakers or just one of them?
Old Aug 12, 2001 | 06:36 AM
JeepRage's Avatar
you want to tap in to both sides. thats the way i did mine at least. if the amp has the input for both sides, do it... it might make it a fuller sound from a stereo sound spectrum or somethign. goodluck
Old Aug 12, 2001 | 11:05 AM
DaMaxima's Avatar
So whould that mean I need 2 converters one for each side?
Old Aug 13, 2001 | 11:22 AM
PimpMoMax
heres how its done.
No you do not need 2 converters. When you buy a high low converter, which is what I assume you will be doing, it will have 4 wires. On the left speaker, take off the plastic housing and you will notice 4 wires going in to the amp, and 2 wires coming out of the amp into the speakers. Those 2 wires are to be connected (spliced, or whichever way you'd like to do it) to 2 of the wires on your high low converter. I believe green is positive and red is neg (if you look closely I think it says). Then, on the other speaker, do the same, hook the other 2 wires up in the same fashion = and -. Unfortunately for me, I had splice the wires and run additional wire to make up for the legnth of the wires on the converter. Whatever works for you.
Old Aug 13, 2001 | 06:23 PM
DaMaxima's Avatar
thanks man.
chisam14
Nov 6, 2018 08:56 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
