Adding Amp to Bose
Is this the signal converter I need to add an amp to the bose system in the link below?http://www.sounddomain.com/shop/item...SANAR95&vq_id=
Also what type of wire do I run between the amp and the signal converter?
that would work...but are you just adding an amp and subs? or replacing all the speakers? I just added an amp for my subs on saturday I used a $20 PAC converter from circuit city. It is 4 wires, easy to hook up, and works great. This unit allows your head unit to take RCA's and RCA's are what you run to the AMP. Hope this helps.
-97semax
-97semax
Originally posted by DaMaxima
Yes I am planning on adding some subs and an amp. So you mean with the pac box i need to buy RCA wires also?
Suggestion is get a good panel popper (trim remover) b/c when you go to get the vents out u need a good tool. I got mine at Advance Auto Parts for $5. No ripples in the dash very efficient tool.
-97semax
With the pac box will i have to do any splicing of the wires?
But yes you do have to splice but it isn't hard.
-97semax
