what's the best way to fit a 6.5" into the rear deck?
Old Sep 2, 2001 | 07:56 PM
djslinkyz's Avatar
i read on maximadriver.com that i should use 1/4" plywood. any other ideas?
Old Sep 2, 2001 | 08:42 PM
Critical's Avatar
Not
sure what you mean by "rear deck" ... rear door? or behind the seats?
Old Sep 2, 2001 | 08:54 PM
djslinkyz's Avatar
Re: Not
behind the seats. there aren't any speakers on the doors.
Old Sep 2, 2001 | 09:27 PM
Critical's Avatar
Well
then if you're referring to just bolting boxes behind the seats A: that's *** ugly and B: you can buy prefab boxes that will work just fine for them.
Since you're mounting them in the back i'm assuming they're more for rear passangers not the front passangers so cutting and dropping them in would be my preference.
Old Sep 2, 2001 | 09:41 PM
djslinkyz's Avatar
okay, lemme try to explain...
the rear speakers. on top of the deck behind the seats. where the 3rd brake light is. 6.5's are a little smaller than the "oversize 6.5's" that Nissan uses. so i need to make something to screw my new speakers into, and then that will be screwed to the deck. is that a little clearer?
Old Sep 2, 2001 | 09:52 PM
Nathan's Avatar
Hey, I'm having the exact same problem. I'm also looking for some ideas for mounting my 6.5" in my front doors and the rear deck. Stupid Nissan had to make oversized 6.5's. I think I going to get thin pieces of wood for the rear deck but I don't know what to do for the front doors. Let me know if you find anything. Thanks.
Nathan
Old Sep 2, 2001 | 11:40 PM
TurDz's Avatar
okay, I've had this problem too and whitemax helped me out. Just use 1/4'' luan wood and cut out "rings" that fit onto the rear deck. I forgot the exact specification but be sure to measure the mounting width of the speaker basket, and make that the size of the inside ring shape. The whole piece should be able to lay on the rear deck flat, and you should be able to have some room to drill a few holes through the wood and into the sheet metal deck.
That's the simple way to do it.
For the fronts, you have to pre-fab some custom baffles. Use wood, or fiberglass, to match the height of the factory baffles (the black plastic ones).
The sizing is a variable, so experiment. It'll be good for you
Old Sep 3, 2001 | 08:09 AM
djslinkyz's Avatar
yeh, that's what i'm going to do.
the front is the same way? shiet...
Old Sep 3, 2001 | 09:10 PM
djslinkyz's Avatar
after a lot of work, i got 'em in. thanks yall
Matt93SE
May 24, 2019 02:58 PM
AcuraLegend
Oct 17, 2016 08:47 PM
jskirwin
Jun 8, 2016 08:49 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Mcnabb34
Aug 11, 2015 08:45 PM
