deck mounting position
Old Oct 27, 2000 | 03:26 AM
mingo's Avatar
ok after making sweet love to my computer, she decided to let me scan all i want without freezing up.. hahaha. but here's a pic of my cva-1005 mounted using the stock holes on the mounting brackets.
and here is it flush mounted.
hope ya'll enjoy the pix. ok on to the next post.
[Edited by mingo on 10-27-2000 at 10:32 PM]
Old Oct 27, 2000 | 08:33 PM
mingo's Avatar
fixed
Old Oct 29, 2000 | 07:49 PM
CKNY's Avatar
How did you flush mount it? Did you drill new holes in the mounting brackets?
Chris
Old Oct 29, 2000 | 07:52 PM
mingo's Avatar
yeah it's really easy, hagn on lemme scan some pix of the mounts and stuff. but you to use a large drill bit to drill out the old holes because of the groves they had.. and use a drill bit the size of the screw hang on i'll b back shortly with pix.
Old Oct 29, 2000 | 08:59 PM
mingo's Avatar
ok like i have promised here are pictures of the mounting brackets. it's actually real easy to do. just use a ruler to measure how much the deck stick out, then on the brackets measure the distance from the center point of the factory holes and make your mark. make sure the mark is in a straight line. draw a line from one center point of the hole in the front to the rear. and place the mark on the line, that way your deck will be mounted on straight.
i hope these pictures help. to lower the deck or raise it's position. simply take measure ments of how high you want the deck to go while it is mounted using the stock holes. draw a line going from the front upper and lower holes on and make your marks on the line. repeat process until completed.
Old Nov 1, 2000 | 03:04 PM
CKNY's Avatar
Gotta do that...maybe this weekend. My deck sticks out slightly and it's ugly haha. I was thinking about doing this, now I know I will. Thanks for the pics! =)
Chris
Old Nov 1, 2000 | 08:11 PM
mingo's Avatar
nP i'm glad i was able to help.
Unclejunebug
Apr 2, 2016 05:42 AM
magiconthetire
Oct 26, 2015 09:03 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
