passive crossover mounting
Old Sep 22, 2001 | 01:11 PM
playas33's Avatar
For those of you with components in the front, where did you mount the passive crossover?? I am kinda clueless so any help will be much appreciated.
Old Sep 22, 2001 | 01:16 PM
2000MaximaSE's Avatar
I used industrial stength double sided mounting tape and mounted it inside the door up against the interior side. This way its out of the way, easy to get to, and wont get wet..
Adam
Old Sep 22, 2001 | 01:34 PM
playas33's Avatar
You didn't think about drilling it in and securing it to the door...i take it you haven't had a problem of it falling off???
Old Sep 22, 2001 | 01:44 PM
Man i probably reaches 150 degrees inside my door and it hasnt fallin off yet... Plus there is no holes on my crossover to mount it anywhere
adam
Old Sep 23, 2001 | 09:15 AM
Micah95GLE's Avatar
I mounted mine to the inner sheet metal with factory holes.
Old Sep 23, 2001 | 01:39 PM
ngthing's Avatar
I ran new wires into my door, and used zip-ties to zip tie the crossover up under the dash area. Easy access, won't get wet, and dosen't rattle itself everytime I shut the door.
Old Sep 23, 2001 | 05:51 PM
max'n out's Avatar
putting the passive x overs in the door is a bad idea put them in the kick panel. I fyou have your speakers there put them high in the dash or under the console.
Old Sep 24, 2001 | 07:08 AM
playas33's Avatar
Thanks for all the help, I am gonna try and mount the crossovers in the car, if I can't, I think I'll just mount them in the door with factory holes.
Old Sep 24, 2001 | 08:13 AM
Dustyroads's Avatar
If you have an excess of speaker wire, you can mount the x-overs in this location.....
Looks pretty sweet and I'm planning on making a trim piece for it to cover up the wiring.
Old Sep 24, 2001 | 04:26 PM
Micah95GLE's Avatar
I've had zero problems with the xovers in the doors. It's less wire to have to run into the door, too.
Unclejunebug
Apr 2, 2016 05:42 AM
Pnjboyzz
Nov 16, 2015 12:27 PM
Pnjboyzz
Oct 7, 2015 10:47 PM
sliptap
Sep 30, 2015 05:57 AM
