High pitched noise coming from spearkers. Need Help!
Old Oct 29, 2000 | 04:43 PM
SkyXRacer's Avatar
I just install some front and rear MB quartz speakers with two rockford fosgate amps. Anyways anyone knows how to get rid of the anoying noise everytime i press on the gas.
Old Oct 29, 2000 | 05:14 PM
Blu Max's Avatar
How did you run your power and rca cables
are they next to each other?
Old Oct 31, 2000 | 06:07 PM
mrloyd
pain in the ***. OK here goes, do these things, in order, when your noise is gone, you win. If it won't go, start buying noise filters. Oh, and if your deck isn't hi volt pre out, that makes it harder. Finally, check for noise after each step. GO! First, try turning down the gains on your amps. You will have to turn head unit up louder, but can eliminate noise. Next make sure amp isn't mounted to metal chassis, if this is the case remount amp to a piece of wood, and mount wood to metal, or just mount amp to box. Next make sure power wire is on driver, rca on passenger side. Don't let these wires cross each other. Make sure you have twisted pair rca's, says so on box. Next make sure your amp is grounded good. Use same gauge as power wire,and make sure to file off all paint from grounding surface. Next, reground your deck. Max has bs factory ground. Just run ground wire from deck to chassis, no paint, and ground. Next, try unplugging antenna and see if noise goes away, if so get antenna noise supressor. Next, try taking radio out of dash. If noise goes away then it is being radiated in by other wires and you should try to wrap the deck in copper foil. As last ditch, try running ground from amp, and/or deck to negative battery post, if works, make the jump permanent. If none of this works, try to find a ground loop isolator. This item plugs in to rca's. NOT an rca noise filter, but ground loop isolator. This worked for me when all the rest failed.
Hondarydr
Dec 30, 2024 06:15 PM
vybz05
Dec 10, 2015 07:38 PM
Starrider
Sep 17, 2015 07:26 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
egali045
Aug 16, 2015 01:19 PM
