Need Help with System Upgrade...
Old Oct 14, 2001 | 06:16 PM
SilverBullet98's Avatar
I have decided to keep my Max and upgrade it...I want to tweak my system to make it sound better...I need help with the following things
1. Subs - 10's, 12's. what brand ect...
2. Amp for my front and rear speakers and tweeters
3. Power Cap...do I need it, which one...
Anything else I can do to make my systewm sound better...Thanks for any advice you guys could give...oh, and I'm kinda on a budget, so nothing too expensive....
Old Oct 15, 2001 | 02:44 PM
How are the 12 inch JBL GT's ?? I was thinkinh about getting two of them....
Old Oct 15, 2001 | 03:25 PM
maximadave's Avatar
detailerdaveb@gmail.com
JL Audio
250/1 250 watt sub amp with 2 JL 10W3's (same system I have)
500/1 500 watt sub amp with 2 JL 12W3's (If you like aallot of bass)
300/4 75X4 4 channel amp for mids and highs
Look into Boston Acoustics or JL Audio for Mids and Highs...this decision is up to you everybody ears are tuned differently...
Maximadave
Old Oct 16, 2001 | 03:32 PM
Well, I'm not changing my amp...dont have enough $$$ for that...what are the major differences between the 10's and 12's ?? And I'm kinda confused with ohms....is the lower number of ohms better ??? I was looking at the JBL Grand Touring 12's.....And whats the right way to wire them up ?? I'm really confused, if anyone could help I would really appreciate it....
Old Oct 18, 2001 | 10:35 PM
CanuckAMP's Avatar
For faq's on Ohm's law as it relates to speakers and amps visit www.mobileaudio.com/rac-faq or http://go.to.bcae
If you're looking for 12" subs and you have some available space you're willing to give up consider the Adire audio Shiva's www.adireaudio.com. They are decent woofers and can get very loud with little power in the right enclosure. They aren't very expensive either.
Other good brands of inexpensive subs are Image Dynamics ID and IDQ series, JL Audio W0 series, Oz Audio Vector series, DEI Pro+ series....
Old Oct 20, 2001 | 03:05 PM
jmax
If you are not changing the amp then you need to get subs that will work well with the available power and impedance considerations. Most 12's can move roughly 40-60% more air than a comparable 10. A lot of manufacturers use the same motor assembly with their ten and twelve which means that power handling will be very similar. But the 12 inch cone weighs more so is less efficient in that regard, but moves considerably more air, so is it really more efficient? Up to you to decide which you want.
Old Oct 21, 2001 | 05:10 PM
phat89max's Avatar
Look in to MB Quart mids and highs and also look into JL Audio 12W6's
PPI amp for the highs and a Rockford BD1000 for the subs it will sound great.
Old Oct 21, 2001 | 06:20 PM
Update...
I bought 2 12 inch MTX Thunder 6000's this afternoon...Now my question is what amp shouls I get to power the 2 12's...They have 500 watta each....What are good amps that will power these and sound good....JL, Rockford, ? Is My Sony amp good ? Thanks
Old Oct 22, 2001 | 12:43 PM
jmax
I would get a class D mono sub amp that will deliver between 400 and 600 watts RMS into a 2 ohm load. The subs are rated for 250 RMS each, wired in parallel will yield a 2 ohm load. Check RF, Harrison Labs, MTX, Directed, MMATS, and about 100 other brands. The Harison is probably the best deal watts per dollar. Ampman Audio sells them.
www.ampmanaudio.com/index.asp
Old Oct 22, 2001 | 03:28 PM
My friend can get me the Rockford Fosgate Power bd500...It's a class D amp, 500x1 watts at 2 ohms.....How are RF amps ? And how is this power for my 2 12's ?? Also, how can one channel of the amp power both subs...I thought that each sub needed it's own channel.... and how should I wire up the subs to make them 2 ohm ??? Thanks for the help....
Old Oct 22, 2001 | 05:08 PM
jmax
RF's are one of the more efficient and good quality. There is probably one speaker output, but RF may have put two as a convenience. Either wire each speaker back to the amp with it's own wires, or wire pos(+) from amp to pos(+) of first speaker, from there to pos(+) of second speaker. Do this same procedure with both speakers. The four ahm load will be wired in parallel, so the amp will have a single 2 ohm load. This will be plenty of power for these speakers that are only rated 250RMS/each. The amp will probably put out more power than this, but not significantly. Audible distortion will be noticed before they blow.
Old Oct 22, 2001 | 07:32 PM
phat89max's Avatar
Black90SE you should get the BD1000 it will hit alot harder.
Old Oct 23, 2001 | 12:21 PM
jmax
Actually doubling the amp power only increases output by 3 dB. And the speakers are only rated for what the BD500 is rated to output. So getting the bigger amp will only be louder for a minute or two, then there will be an interesting electrical singe scent coming from the voice coils.
Old Oct 23, 2001 | 07:53 PM
CanuckAMP's Avatar
Yeah you would wire the subs to create a 2 Ohm load to get the most out of that amplifier. Mono amplifiers such as these are stable into lower loads allowing multiple subwoofers to be connected. The total power is then split between teh two subwoofers.
Alot of Class D amps actually have 4 output speaker terminals on the to make it easier to install 2 speakers in a parallel setup. What happens is the 4 outputs are actually already paralleled inside the amplifier.
Old Oct 24, 2001 | 04:39 PM
So will the bd500 be good for my subs ?? I want them to really pound...But sound good also.....So is the bd500 the right amp ???
Old Oct 25, 2001 | 12:42 PM
jmax
I don't know that there is a single "right amp" for any system, but the BD500 is definitely on the list of "good choices."
Old Oct 26, 2001 | 01:01 PM
CanuckAMP's Avatar
Yeah I'd say it's certainly a decent choice for your setup....
Miket2006
Mar 1, 2021 03:55 AM
MichMaxFan
Sep 30, 2015 09:18 AM
Socalstillen
Sep 26, 2015 12:01 PM
RWCreative
Sep 21, 2015 11:01 AM
