1" tweeter placement?
Old Oct 2, 2007 | 10:19 PM
travmaximas1998's Avatar
i know where the stock bose tweeter is placed.
has anybody placed them anywhere else?
Old Oct 3, 2007 | 04:38 AM
djfrestyl's Avatar
Suspension Yoda
In the doors, sail panels, kick panels, the list goes on.
Old Oct 3, 2007 | 09:38 AM
is there room to place them inside the speaker cover next to the 6.5" driver?
Old Oct 3, 2007 | 10:15 AM
DcMaN's Avatar
If your maxima is from 1998, i would just dremel out the factory tweeter position and place it in there.
Old Oct 3, 2007 | 06:25 PM
the stock placement of the bose?
Old Oct 3, 2007 | 06:29 PM
WhiteA32's Avatar
Yeah you can pop out the tweeter hole as is and add it there or just put it behind it
Old Oct 3, 2007 | 10:50 PM
so the stock door panels without the bose system already have a spot for them that all i have to do is pop out?
Old Oct 4, 2007 | 08:08 AM
WhiteA32's Avatar
Do you have tweeter holes?
If so yes, just pup them out and I think you may have to cut them a lil to it fits.
Old Oct 4, 2007 | 10:06 AM
im not sure if i have the holes or not. its a stock door panel. and i havent tried to take it off yet cuz i only wanna take the door panel off once.
Old Oct 4, 2007 | 10:19 AM
WhiteA32's Avatar
OIC...But you don't have to take off the door panel to see if you have holes for the tweeter, You should see a grill above the door handles on the inside of thecar
Old Oct 4, 2007 | 10:29 AM
ya i dont have those its just a stock maxima, it doesnt have the bose system. i thought yal were saying it sort of has a pre-hole thingy on the inside the door panel so when at the factory the installers know where to put it.
Old Oct 17, 2007 | 01:35 PM
I30driver's Avatar
I have been putting my tweeters on the A pillars for 10+ years now. It is the best for imaging IMO. I mount them with silicon, so removal leaves no holes or marks, except some faded plastic.
I am recently starting to hear about people putting small midranges up there also like the Legatia3. That is something I would love to hear before I attempt it.
Old Oct 17, 2007 | 10:16 PM
maxgtr2000's Avatar
KH3 by popular demand
Yeah, seen someone that won world sq finals with that type of setup; that would be a challenge to accomplish tho but the wonders of fiberglass. I have some mb quarts tweets fiberglassed into my A pillars at about eye level.
Old Feb 29, 2008 | 08:51 AM
AustinTylerDean's Avatar
The distance between the A pillar tweeter mount, and the woofers in the door is killing me! Maybe I chose the wrong speakers for the job. Polk Audio MMC-6500.
Anyway, does anyone know if I am retarded for sending the (RF Punch 500.2)amp'd signal directly to the woofer in the door, and having the crossover feed the tweeter? I am trying to "fill" the gap, so to speak, so any 100-200+ hz I can get coming out of that woofer, the better...
Upon reception of suggestions, much appreciation will follow.
Old Feb 29, 2008 | 11:37 AM
dashan's Avatar
I have a set of MMC650 but I separated the tweeters from the woofer. I got very good sounds by mounting the tweeters on the A pillar.
MMC6500 is twice expensive compared with MMC650. I talked with a Polk tech over the phone. The guy told me that MMC6500 was expensive because a lot of efforts were spent on developing the crossovers. The crossovers for 6500 are very, very good. You should send the signal through the XO to the woofer. Add a subwoofer if you want the sounds at a lower frequency.
Old Feb 29, 2008 | 01:46 PM
Fast1one's Avatar
X2, also get a dash mat, it has been suggested by many competitors to battle early deflections...Play with phase as well since you are running passive and can't apply time alignment to each individual woofer/tweeter...
I have been toying with the idea for a while, and I will finally do it by the end of this month...3 inch full range drivers fiberglassed on the A pillars...stay tuned
95naSTA
Sep 21, 2015 06:50 PM
mpbclutch33
Sep 21, 2015 01:54 PM
MikesChevelle
Aug 9, 2015 11:50 AM
SE-Raider
Dec 29, 2000 08:56 PM
Maxima95GLE
Dec 7, 2000 11:02 AM
