How to wire remote start in 5 speed
Old Oct 22, 2001 | 06:42 AM
delio's Avatar
Has anyone done it in a 5speed 4th gen? Easiest way? Thanks,
Del
Old Oct 22, 2001 | 01:11 PM
chinaonnitrous1's Avatar
remote start for manual transmissions is pretty similar....bascially the wiring is the same for the ignition, starter etc... but the only difference is that the clutch switch needs to think it's being depressed...now with maxima's i think when you depress the switch you get 12volts...enabling the car to start...now all you need is a relay or use the extra 12v output from the remote start to give that switch 12volts so the car thinks the clutch is depressed...OR it could be that when the clutch is depressed...it shows 0 volts..so you need to reverse the polarity of the relay.....but the only extra thing you need to do is find the clutch switch and wire up a relay. I hope this helps..sorta...e-mail me if you need some exact directions on the relay... Just so you know......unless you plan on installing some mercury switches on you shifter...or some sort of safety device..if you remote start in gear..your gonna have a accident!
Old Oct 22, 2001 | 01:15 PM
delio's Avatar
I understand about the accident part
Where can I tap into this clutch switch...would you happen to know what it is called by nissan so I can look it up on the FSM.
Old Oct 22, 2001 | 02:14 PM
Re: I understand about the accident part
if you can..just look under the dash..follow the clutch pedal up...grab a flashlight if necessary..you see..the arm of the clutch hit a pin style switch....try this..if you locate the switch..put the car in ***NEUTRAL***!!!!!!.....press the switch with your finger or something..and try to start the car.....if the car starts in neutral...and our finger is pushing that switch down..thats the one. I dont know the "techincal" name for it tho. but make sure its in neutral...man..it gets ugly when your leaning under the car upside down..pushing the switch..and starting and having the car jump..woohoo..talk bout bruises (i was watching!! not in the car)
Old Oct 23, 2001 | 08:06 AM
delio's Avatar
I have done enough installs
I am totally comfortable around the car.... Shiet try contorting your body to get your hands in position for some of the bolts on the Supercharger... WOW! I was cleaning motor oil off places I didn't know I could bend.
Anyone else wanna add their 2 cents?
Old Oct 24, 2001 | 08:47 AM
delio's Avatar
No one else
has anything to add to this...like maybe exactly which wires to splice into etc...
vingodine
45
May 21, 2016 12:46 PM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
conansriver
Sep 3, 2015 06:38 AM
doobadoo
Aug 15, 2015 06:43 PM
maximaham
Aug 7, 2015 01:11 PM
